Project of the Month built by Rustkolector
Home Model Engine Machinist > Building Them > Plans > Bugatti engine
Old 08-31-2011, 08:45 PM   #1
mgbrv8
Liked 14 Times on 13 Posts
Default Bugatti engine
Dose anyone have plans for a old bugatti engine? Or know were to find them
mgbrv8 is offline
Old 09-01-2011, 12:30 AM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 950 Times on 640 Posts
Likes Given: 8
Default Re: Bugatti engine
I have a 1/4 scale 50T about 3/4 of the way done. Now that I have been building engines for a while I'm not very proud of the engineering. If you want a place to start you could build on the plans. Knowing what I know now, I would'nt build to what I have.
http://www.homemodelenginemachinist....p?topic=8151.0
stevehuckss396 is offline
Old 09-01-2011, 01:20 AM   #3
mgbrv8
were would you look for plans or original drawings?
mgbrv8 is offline
Old 09-01-2011, 02:00 AM   #4
stevehuckss396
Senior Member
Likes Given: 8
An organization called "The Bugatti Trust" has possession of tens of thousands of the original drawings. They require a copying fee of $5 a sheet. The T50 had 400 drawings to complete the engine alone.
Old 09-01-2011, 06:39 AM   #5
mgbrv8
Well that puts a damper on things.
mgbrv8 is offline
Old 09-01-2011, 12:51 PM   #6
stevehuckss396
Senior Member
Likes Given: 8
I thought the same thing. If you want my drawings all the basic dimensions are correct. I reworked them about 2 years ago. The basics are solid. I might make changes like pressurized oil system. I would loose the belt in the fromt and go gears so I could also drive the water pump and blower. One piece crankshaft.
Old 09-01-2011, 03:05 PM   #7
mgbrv8
I will send you a PM with my email address
mgbrv8 is offline
Bugatti ironman The Break Room 1 05-09-2010 06:57 PM
