Project of the Month built by edholly
Home Model Engine Machinist > Showing Them > Photos and Videos > CAT 3406e Diesel engine
Old 08-20-2011, 03:30 PM   #1
bigrigbri
bigrigbri's Avatar
Liked 16 Times on 16 Posts
Default CAT 3406e Diesel engine
Heres some pics of my work in progress of the notorious Cat 3406e truck engine.
Made from a pattern done by myself on the block and with purchased gears
[img][/img]
Why buy one when you think you might be able to make one, eh......* soon?
bigrigbri is offline
Old 08-20-2011, 03:45 PM   #2
Shopguy
Liked 15 Times on 14 Posts
Likes Given: 14
Default Re: CAT 3406e Diesel engine
That's a beautiful piece of work. Your castings look to be right on. I'd be interested to know what you propose for the injection system.
And welcome to this forum.
Ernie J
Ernie J. I'm living in the shadow of the Canadian Rockies and loving it.
Shopguy is offline
Old 08-20-2011, 03:51 PM   #3
MachineTom
Senior Member
MachineTom's Avatar
Liked 117 Times on 88 Posts
Likes Given: 7
That is beautiful, great workmanship. Have you figured out the E-injection yet. Will the injectors be E controlled? Can I guess the truck will be a 379 L ?
My Wheels don't slow me down
MachineTom is offline
Old 08-20-2011, 04:14 PM   #4
bigrigbri
bigrigbri's Avatar
Thanks for the reply guys.
I will be puttin it in a 379l yeah.
For the in jection system I will be going the electronic route as ful scale and will be using 6 opto tranceivers at the back of the head on a distributor type of layout at the end of the camshaft fitted stealthfully as possible.
These will control 6 seperate circuits utilizing the 555 timer configured into monostable allowing adjustments on the internal resistance and capacitance giving varying output timing widths.
This output will be controlled through power transistors to handle the inductive loads of the valve coils.
For the mechanical side of the injectors I will be using the pintle ends of small full size injectors to act as the cam driven pump as these are micro finished in accuracy and i dought that I could replicate such a feat in the home workshop.
Small motorbike injector coils will be tried with the valving that comes with them as a "suck it and see".
Huge task all the same .
I have had the engine spinning in the lathe lashed up with the cam belt system to check for cam timing and to see oil pressure operates as should and to bed in some.
Had to squirt some model diesel fuel in there though as it spun to see poppin and black smoke!!!
Got some bore roundness issues though as the rings aint touchin fully around .
Brian
Old 08-20-2011, 04:22 PM   #5
bigrigbri
bigrigbri's Avatar
Short engine spin vid not running.
Old 08-20-2011, 05:27 PM   #6
Admiral_dk
Liked 4 Times on 4 Posts
Beautifully done !!!
But I must admit that I'm a bit confused about what I think I see on the pictures.
Are there three camlobes per cylinder or is that just a trick of the light ?
How does the camfollower handle two valves that aren't equally distanced from the pivot point ?
Could you show us a close up picture of the valves, cam and follower on one cylinder please ?
Admiral_dk is offline
Old 08-20-2011, 06:05 PM   #7
MachineTom
Senior Member
MachineTom's Avatar
Likes Given: 7
This type of electronic injection uses a camlobe to run the pump portion of the injector, and a solenoid inside the injector to control fuel timing, start and stop duration = quantity. There is a bridge that connects two valves to one rocker arm for breathing.
A very ambitious project for sure. The full scale injector parts are not very big at all, 1/5 are real small.
You are using a Pintle type injector for a pump? would not a needle type be a better pump? just thinking out loud.
Old 08-20-2011, 07:51 PM   #8
steamer
Liked 104 Times on 100 Posts
Welcome!
I am looking forward to this engine taking shape!
steamer is offline
Old 08-20-2011, 08:57 PM   #9
ShedBoy
Senior Member
ShedBoy's Avatar
Liked 41 Times on 42 Posts
Likes Given: 17
Them block anh head castings look amazing. Do you have any photos of the casting process, I for one would love to see them. Oh and welcome.
Brock
Are you using CNC or doing it manual.
Don't follow me I'm lost too!
ShedBoy is offline
Old 08-20-2011, 09:14 PM   #10
doubleboost
Liked 30 Times on 29 Posts
This is simply stunning work
I would love to see the patterns & coire boxes
The downstairs loo is very handy for cooling welded parts
doubleboost is offline
Found this 0.1CC Micro Diesel engine AssassinXCV The Break Room 24 01-24-2014 09:51 PM
Diesel Engine Model - run off biodiesel? mnbylcr2 General Engine Discussion 7 08-31-2013 09:53 AM
diesel engine with pistons for valves FIXIT General Engine Discussion 6 12-07-2010 06:47 AM
Das Boot Diesel engine model? ieezitin General Engine Discussion 6 02-14-2010 04:15 PM
How to start a real diesel engine crankshafter Photos and Videos 10 04-10-2009 12:56 AM
