Project of the Month built by Johno1958
Home Model Engine Machinist > Building Them > General Engine Discussion > hooking up a clausing 5914 lathe
Old 08-12-2011, 01:24 PM   #1
Liked 11 Times on 11 Posts
Default hooking up a clausing 5914 lathe
well i just bought a clausing 5914 lathe for a came out of the plant where i work, but did not get to see it run,it got unhooked before i got a chance to start it up. it is in like new condition, but do not know about the variable speed drive. i would like to get it up and running but not sure about the best way to convert 1phase to 3 phase,vfd or rotary. will a vfd work ok with the variable hyd. speed, or do i need to use a rotary converter, or just remove the variable hyd. drive to a pulley set-up. thanks for any help. jonesie
jonesie is offline
Old 08-12-2011, 03:28 PM   #2
Senior Member
MachineTom's Avatar
Liked 123 Times on 93 Posts
Likes Given: 7
Default Re: hooking up a clausing 5914 lathe
For a lathe application, stick with the Clausing variable system. A Lathe needs lots of torque for big turning, tapping etc. You will not get that with a VFD alone. I have a RPC to convert to 3 phase, works fine, I installed it in the garage but the noise finds its way into the workshop anyway. A VFD is almost silent, uses no power at idle, and is cheaper to purchase, and use.
To use a VFD from single to 3 phase, you need to purchase a unit double the size of the largest motor it will run. IE: 1 hp motor needs 2hp VFD, the controls of the lathe On/Off FWD/Rev need to be controlled by the VFD, not the motor controls on the lathe. A 5914 is a vary belt drive not HYD as far as I know. This is fairly simple to do for anyone familiar with electrical wiring, all controls would be low volatage through the VFD.
I had a VFD on a SB 16 Lathe, it was necessary to shift the belts for enough torque for the large D parts, and running taps and dies. The 1944 vintage motor did not blow up at 50% overspeed, but I was uncomfortable with pushing it higher. Slow motor speeds are what invertor duty motors were designed for, as it causes great heating of the stator windings due to the frequency used in VFDs
about 15K hz, so non invertor rated motors could fail at continued low speed high load conditions.
If this will be your only 3 phase machine, go VFD, if you might ever get a mill or grinder, then a RPC makes sense, of you would need a VFD for each machine.
My Wheels don't slow me down
MachineTom is offline
Old 08-14-2011, 02:10 AM   #3
machinetom thank you for the reply i think i will go with the vfd drive., and leave the motor set-up as it is. thanks again jonesie
jonesie is offline
Clausing 8520 - Low range?? terrywerm General Engine Discussion 13 07-19-2012 12:02 AM
Clausing 8250 mill? lazylathe Tools 99 04-08-2012 12:37 AM
Can anyone identify this Clausing mill? bjo Buy / Sell / Trade / eBay 10 02-14-2010 09:46 PM
10"Clausing lathe synchronous belt oncenter General Engine Discussion 1 10-11-2009 03:40 PM
Hooking up a VFD to my mill kvom The Shop 17 01-05-2009 03:07 PM
