Project of the Month built by Johno1958
Home Model Engine Machinist > Showing Them > A Work In Progress > 1/10 SCALE V8
Old 08-04-2011, 05:07 PM   #1
Default 1/10 SCALE V8
Hey guys did my introduction and someone asked what scale i planned on making my engine to i didn't really place all the details in the intro post as i felt it should be really just that an introduction as to who i was and what i was here for.
So now some details on the engine. Its more or less based on a ford 302 small block commonly known in the states as the 5.0 being a ford guy and that being one of my favorite engines of all time i decided i had to make one after seeing gbritnells awesome 1/3 scale one.
It seems i cant find my binder of drawings and dimensions at the moment probably downstairs in the garage. Anyways i followed the bore and stroke ratio of 4/3 and scaled down until i hit a displacement of 497cc or 30.2 ci 10% of full size. Now the bore and stroke of course isn't perfectly scaled in their new dimensions but the ratio matches and scaling volume doesn't work as easily as linear dimensions or area.
Let me say though that a perfect scale model of a ford 5.0 is not my primary goal the bigger goal was to match the displacement scale i wanted then of course lots of dimensions of the crank and cam and positions had to be scaled or i had to engineer it to work how i wanted.
I'm trying some new things not really common to full size engines or even really done on scale ones.
I'm not going to be using sleeves and cut in water jackets but instead I'm going to have a water jacket that closely follows the cylinders but its a complete groove around the top. My first though was to make some kind of sealing plate to seal the water jacket but that would just be a pain in the ass to say the least. So now comes some racing technology copper o-ring seals. All of the cylinders will have a .025 groove cut to allow for a copper o-ring of my design to be placed in and when the head is torqued down the ring will compress and hence for seal the cylinder to the heads combustion chamber while allowing for over the top water flow and cooling capacity.
I thought about ignition for a while now distributors obviously work as almost all engine use that setup but being that i want to go against the grain and do something different i was thing of do a crank trigger setup with coil packs. I know never seen on a scale engine and a bundle of extra work for something that wont really make a big difference. But hey if we don't try to do something different every once in a while we get complacent.
Now i doubt this hasn't been done but i cant really find any info about it. DRY SUMP oiling i wish i could give a good explanation of it for those who don't know but it is a much more effective form of oiling your engine which allows for bigger power gains and it allows the engine to work less to make the same power. Wet sump works but when i have to make most of the parts myself anyways why not go dry sump but for oiling passages I'm some what at a loss so any help is appreciated.
The heads are my nightmare at the moment because i don't have one to take dimensions off i mean LxWxH is meaning less cause i have changed things up but the angles i need at least the most common ones. Such as the angle of the intake ports versus flat line of the head and what angle the valves should be at vs flatline of the head. Ive been using 18* which seems ok but as stated its giving me a headache at this point and any incite would be great.
Fuel system is confusing me to i want to make 2 setups one that is N/A and a Boosted model. The N/A version i speak of is ITB essentially a carb for each cylinder. I have no idea what carbs to use or how to make my own for that matter. I'm thinking a decent r/c engine carb would work just find and i can easily obtain those. for the blower i wanted something like a 4 barrel Holley which i could make in theory but I'm not really a carb engineer and have no really grasp as to how to go about designing one.
I'm doing all my modeling within mastercam x5 not the best for modeling but being as i taught myself how to model about a month ago its more then enough. I have autocad, inventor, and solidworks but have no real experience with the latter 2 and the new interface in autocad annoys the hell out of me. Id like to get most of my modeling done then ill tolerate that new interface and start the drawings applying GD&T to all dimensions.
The goal of this project is to not only have a pretty working engine but to have it fully documented with plenty of photos and video. I will have multi view drawings of all parts with dimensions and solid model pictures to accompany them.
I want anyone with the desire to be able to recreate this. Once i have finished everything i will post it in the download section as a RAR file for free download to anyone interested that just a small donation from me and ill try to be fast about it.
Ill upload some photos of the solid model of the block and heads they are by no means finished and any advice is very welcomed. the block is really still in design phase and i feel that i have to much material in front and back of the cylinders as far as overall length goes but maybe I'm wrong
schmetty is offline
Old 08-04-2011, 06:01 PM   #2
b.lindsey's Avatar
Liked 63 Times on 62 Posts
Default Re: 1/10 SCALE V8
Sounds like a very challenging project and I wish you the best with it. One comment as to drawings. Generally most model work does not require GD&T, and it adds complexity to the drawings which in my opinion is not needed. Nothing wrong with GD&T at all, but i find it more applicable to the quality control and inspection of critical parts moreso in a production setting. Others may have different opinions though. Another thing I have found is that on more complex projects things often change along the way, which impacts other parts as well. so try not to let that get too far ahead of you. Once you note such a change, go back and change the drawings for mating parts at the same time as appropriate. Keeps up posted as you progress.
skype: william.lindsey.iii
b.lindsey is offline
Old 08-04-2011, 09:10 PM   #3
Senior Member
ShedBoy's Avatar
Liked 41 Times on 42 Posts
Likes Given: 17
Thanks for the detailed description of what you want to accomplish. I will be following along.
Don't follow me I'm lost too!
ShedBoy is offline
Old 08-04-2011, 11:04 PM   #4
Liked 108 Times on 97 Posts
Likes Given: 3
I look forward to seeing this come to life. 10% volume is about 46%scale. That's fairly large! At this size you really can include some tech if you desire. When you're done you can put it into a sled or quad.
Don't tell anyone , but this site is full of information right up your alley. If you haven't seen it, you'll die. He doesn't give it all away as he makes a living doing it, but plenty to ogle at.
I'll have to agree that even if you intend to sell a set of plans, GD&T is intimidating to most who will buy them. It's mainly to achieve part interchangeability. Rarely will a set of model engineering prints call a tolerance of any kind, only fits where required.
dieselpilot is offline
Old 08-04-2011, 11:33 PM   #5
Senior Member
stevehuckss396's Avatar
Liked 950 Times on 640 Posts
Likes Given: 8
I solved that problem by making a simple RC type carb look like a holley 4 barrel. It's not the same but MUCH easier and still has a little cool factor. Best of luck and I will be looking for a build thread as you progress.
stevehuckss396 is offline
Old 08-05-2011, 08:00 AM   #6
Thx alot guys seems like i might have left a few things out and possibly over explained some things
GD&T wont be used so much as to confuse people working off the plans more solely to provide dimension tolerances for machining and final inspection. Datums and the such wont be used as it can become confusing very fast but expect to see tolerances for diameter, concentricity, parrellism and similar such things but most people will be able to ignore the call outs and just use common sense to make this if they so desire.
I have already changed the block design about 8 times so im sure once i start making chips plenty of changes will come so i always take photos and lots of notes. One thing that has saved me lots of time is actually saving every change or set of changes as a new file so if i need to go back a couple of steps its much easier then deleting a bunch of lines.
As far as the use of this bad boy it has gone through 3 stages. 1st a simple working display piece, 2nd custom design rc car, 3rd and my favorite at the moment shifter cart totally custom from the ground up and obviously built with a full set of jigs and all the sort so it can be re-made over and over with consistency.
I promised pictures and they are on the way im just having trouble with photobucket at the moment so all i can say is theres gonna be a decent amount of pics. heres a heads up of what to expect
The block, heads, the shaft mounted rocker setup, the start of the crank trigger.
Hopefully sometime around sun rise ill have pics
schmetty is offline
1/4 scale V8, first project. keith5700 A Work In Progress 411 07-17-2017 01:22 PM
1/6 scale Chevy V8 mklotz Photos and Videos 23 02-17-2013 06:34 PM
1/4 Scale Cirrus. lantain1982 A Work In Progress 6 06-23-2012 04:17 AM
Digital Z scale Noitoen Machine Modifications 11 01-04-2010 09:36 PM
Scale Hardware is the U.S.'s best source for scale model fasteners. PTsideshow The Break Room 21 05-21-2008 12:57 PM
