Home Model Engine Machinist > Building Them > General Engine Discussion > Babbitt bearings
Old 07-12-2011, 03:07 PM   #1
machineman8625
Liked 2 Times on 2 Posts
Default Babbitt bearings
I poured babbitt bearings and machined them for 25 years. What little I know about babbitt bearings I would be glad to share. I actually do not know why no one seems to use babbitt for model engineering. Larry
machineman8625 is offline
Old 07-12-2011, 03:18 PM   #2
mgbrv8
Liked 14 Times on 13 Posts
Default Re: Babbitt bearings
Larry
When you have a ovaled or worn out bore. What is the best way to pour babbitt in that void. I understand I need to blacken the part that I dont want babbit to stick to with a carburizing flame but what do I need to do to prep the other surfice to help the babbit stick to it. Also what is to small of a void to pour into??
mgbrv8 is offline
Old 07-12-2011, 04:30 PM   #3
GWRdriver
Senior Member
Liked 111 Times on 91 Posts
Likes Given: 27
Seems to me the best way to do it would be to prep the entire bore and pour in a sleeve of babbit and then rebore to the req'd diam.
Harry
GWRdriver is offline
Old 07-12-2011, 06:02 PM   #4
machineman8625
To repair the oval shaped bore, I guess bore it round 1/16 to 1/8 oversize. You can make the babbitt not stick by painting the area with a horsehair acid brush with stove polish that you can buy at any woodstove store. It is just carbon black powder in a alcohol, or some other quick drying liquid. You can actually paint it a second time. To make the babbitt adhere to steel ,brass , or copper, get some soldering fluid in a small 6 to 8 ounce container at any Ace hardware store. If they don't have it they can get it in a day or two special order. Heat the part with a propane torch until the soldering fluid bubbles when you apply it with a acid brush. Then just tin it(apply solder) with lead solder. Just get a whisper coat and then babbitt will stick to that when you pour it. Larry
Old 07-12-2011, 10:47 PM   #5
JorgensenSteam
Guest
Posts: n/a
Larry-
There seems to be several schools of thought about babbit bearings.
My Dad used them for 50 years at his lumber facility for all of the fans in the kilns, and according to him, they were the only bearings that would run for very long periods of time for many years. He did mention that they have to be kept oiled.
Another school of thought comes from one of the old steam engine design books from the late 1800's, where one designer noted that while the babbit bearing itself never wears out, the journal or shaft will wear out, and replacing a journal or crankshaft was a much more difficult problem than replacing a bearing.
Charles Porter of the Porter-Allen steam engine fame (Porter designed the first "high-speed" steam engine in 1876 which revolutionized steam engine design for the next 50 years) preferred to run gray cast iron on gray cast iron, and found that to give the very best wear characteristics of all, and far better than brass.
Old 08-12-2013, 11:19 AM   #6
hpchoudhury
Default
Larry-Can you please share total flow chart of Babbiting Process including inspection process
hpchoudhury is offline
Old 08-12-2013, 12:20 PM   #7
Jasonb
Jasonb's Avatar
Liked 426 Times on 268 Posts
Likes Given: 18
Default
Dave's build thread of his Pacific Vapour Engine shows babbitt used on a model.
http://www.homemodelenginemachinist....tml#post187387
J
Jasonb is offline
a use for your old bearings mklotz The Break Room 7 04-19-2011 11:13 PM
babbitt bearing jonesie General Engine Discussion 5 03-29-2011 04:05 PM
Carlisle + Finch restoration- Babbitt myrickman Engines From Castings 2 01-01-2011 02:25 AM
Something Like Babbitt PolskiFran Metals 6 04-09-2008 02:58 AM
TB1 - Bearings joe d Team Builds 0 04-04-2008 02:24 AM
