Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > General Engine Discussion > Simple IC engine
Old 07-07-2011, 10:45 AM   #1
speedhound
Liked 2 Times on 2 Posts
Default Simple IC engine
What is the simplest IC engine that can be built from stock and how difficult is it to bulid and get running? Have seen Jan ridders simple two stroke but some people say its hard to get going.
Thanks
speedhound is offline
greb Likes This
Old 07-07-2011, 11:50 AM   #2
Brian Rupnow
Liked 4003 Times on 3186 Posts
Likes Given: 36
Default Re: Simple IC engine
I vote for the Webster. Plans are free, thousands have been built, and they are easy to get running.---Brian
http://www.homemodelenginemachinist....p?topic=8388.0
Brian Rupnow
Brian Rupnow is offline
minh-thanh Likes This
Old 07-07-2011, 04:54 PM   #3
RManley
RManley's Avatar
Liked 49 Times on 31 Posts
Likes Given: 8
I vote for the Nemett 15s, its a very nice simple engine to build in either water or air cooled versions and all from bar stock. It runs well and has a long series of how to make it in the Model Engineer magazine.
example:
Building a half size douglas motorcycle....will I be able to ride it? I just realised that a half height human is 3 years old....
Twitter: @VintageBikeShed
RManley is offline
Old 07-07-2011, 06:51 PM   #4
Longboy
Longboy's Avatar
Liked 180 Times on 127 Posts
Likes Given: 77
I did a Webster as my first I/C. I think because being the plans were complimentary on the internet, I could study them for awhile before getting all in. Very satisfied with the results with some self doubt along the way, I am now comfortable taking on I/C. Read about my experiance as a novice builder here! http://www.homemodelenginemachinist....p?topic=8256.0
Model Engines!......keeping me outta the bars and away from the women!
Longboy is offline
Old 07-07-2011, 10:22 PM   #5
Catminer
Liked 14 Times on 14 Posts
How about Gingery's Atkinson cycle, build is described step by step and runs easily and very well.
Book is available from Lindsay's.
Peter
Catminer is offline
Old 07-07-2011, 11:22 PM   #6
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Knowing what machines are at your disposal and the level of confidence/experience you possess in machining would have a direct impact on the answer to your question. If one has free access to a lathe and milling machine, and has the skills to run them, it greatly increases the choices that one has to choose from. Probably the 'simplest' engine option would be "The Webster" as has already been mentioned. Those drawings can be accessed in the downloads section on this site. The Jan Ridder's engines are relatively simple and straight forward as well (although they are in metric format) and should not present any more difficulties to get running if all of the fits are held to a close tolerance. The same can be said for The Webster, or any engine for that matter. If the valves are not painstakingly attended to in terms of getting them to seal 100% and attention to the piston to cylinder wall isn't properly executed, any engine, no matter how simple or complex in mechanical nature will be next to impossible to get running. Best of luck.
BC1
Jim
bearcar1 is offline
Old 07-08-2011, 01:57 AM   #7
kf2qd
kf2qd's Avatar
Liked 41 Times on 43 Posts
The simplest engine is probably going to be a 2 stroke. Crankshaft and piston ports do all the valving, Model airplane fuel and glow plug are cost effective and all you need to get it started is a 1.5 Volt battery. Carb can be a fixed carb with a simple spraybar. Check ou the .60 2-stroke plans I uploaded a while back.
Oh - and another plus - no gears.
KF2QD, South Texas
HF MiniMill, HF 7x10
Hardinge UM, Enco 12x36
kf2qd is offline
bazmak Likes This
Old 07-11-2011, 06:08 PM   #8
speedhound
Thanks for replys, i do have machines cnc and manual, i have built Jan Ridders twin cyl vacuum engine with internal valves and am trying to get it going at the moment but not sure if it will go . I have no experience with an IC engine and was just woundering if it would be possible for me.
Thanks
Old 07-11-2011, 06:35 PM   #9
JohnS
Liked 10 Times on 10 Posts
Hi Speedhound
You may find my experience building Jans Simple Two Stroke of interest.
http://start-model-engineering.co.uk...le-two-stroke/
As you will see I did have initial problems to get it to run. After increasing the compression with a modified piston and cylinder head the engine now starts and runs without any problems. I feel that for anyone taking a first step into IC engines should opt for a 2 stroke for a better chance of success.
a friendly place for model engineering beginners
JohnS is offline
Old 08-19-2017, 09:40 AM   #10
Keith140
Default Debbie engine with spray bar and model glow fuel
Thanks
I have just got my Jan ridders DEBBIE running easy to start and run on model engine glow plug fuel and a spray bar fitted. https://youtu.be/KpeuXRtJy5I
Keith140 is offline
Simple beginner engine Enginedude1 Plans 64 04-07-2013 09:12 AM
My first engine: Simple Wobbler spedding84 A Work In Progress 10 06-26-2012 02:56 AM
Another Uber-Simple Engine SignalFailure Photos and Videos 3 12-22-2009 10:43 PM
Another simple engine idea SignalFailure Plans 0 07-13-2009 05:11 PM
Simple IC engine plans for a beginner. stout1 General Engine Discussion 3 05-13-2009 09:29 PM
