Home Model Engine Machinist > Building Them > General Engine Discussion > Turning small long shafts on big lathe?
Old 06-29-2011, 01:01 AM   #1
jtrout13
Liked 15 Times on 13 Posts
Default Turning small long shafts on big lathe?
I recently built Elmer's Fancy engine and while it performed well, I was unhappy with the piston. I am having trouble turning the connecting rod for this piston (it is a 0.25 inch OD rod, with a section turned down to 0.125 inch diameter, 1.25 inches long).
My lathe is large Romi 13-10. I keep having trouble with one end of the turned-down section being a larger diameter than the other end, and I can't seem to get a constant OD all the way down the turned section. I have tried doing it between centers (difficult) and also tried turning it in small steps of length (only neck down about 0.25 inch at a time) to reduce the cutting force deflecting my workpiece. However, I am still having no luck. (have tried using both HSS and indexable tooling).
Would anyone be so kind as to provide some advice?
jtrout13 is offline
Old 06-29-2011, 01:05 AM   #2
steamer
Liked 105 Times on 101 Posts
Default Re: Turning small long shafts on big lathe?
What is occuring? Taper?, chatter?
Have you leveled your lathe?
steamer is offline
Old 06-29-2011, 01:09 AM   #3
Rayanth
Liked 12 Times on 11 Posts
Also, what's the material? Aluminum, steel?
Have you tried taking more, shallower cuts and gradually approaching the target diameter? I have heard on steel that swelling from heat can cause this issue.
- Ryan
Do your best, paint the rest.
Rayanth is offline
Old 06-29-2011, 02:02 AM   #4
jtrout13
Sorry for the poor description. I am using drill rod O-1, and the problem I am having is taper. Chatter isn't a problem, and surface finish is great, but I'm getting the taper and having problems zeroing in on the final dimension.
Also, it's tough to take small cuts on this lathe due to deflection of the workpiece (the tool just bends the shaft instead of cutting into it), so I am doing a minimum of 0.030in depth of cut (0.060 reduction in diameter).
I have always had great accuracy and never had taper occur with this lathe, but I usually don't turn any diameters smaller than 1/4 inch. This is the first part I've had this problem on, so I'm totally confused.
jtrout13 is offline
Old 06-29-2011, 02:45 AM   #5
websterz
Liked 16 Times on 15 Posts
You need to fashion a follower rest, it will come in handy more often than you'd expect, especially doing model engine parts.
Frank Ford has built a nice version here:
http://www.frets.com/HomeShopTech/To...ifollower.html
websterz is offline
Old 06-29-2011, 06:08 AM   #6
Rayanth
A follower rest is a good idea, but I would still look into the possibility of heat expansion. It's possible you're still cutting true, but as the stock heats it expands, so you're cutting deeper relative to the stock. When it cools and shrinks it shows as a taper. Smaller stock has less mass to soak up the heat and less surface area to shed it, so it gets hotter, quicker.
The follower rest will prevent deflection, allowing you to make lighter cuts, which will both cause less friction so less heat, and give the stock time to cool between cuts.
Of course, your mileage may vary, and i'm approaching it all from the theory angle .... I could be way off base
- Ryan
Rayanth is offline
Old 06-29-2011, 06:38 AM   #7
bentprop
Liked 17 Times on 17 Posts
I believe what you need is a box tool.This feeds the rod to be cut through a sized bush with a cutter being placed after the bush.This allows thin rod to be reduced in size without bending the rod.Of course,you need a bush for every size rod.F.i.,if you want to cut a 1/4" rod to 3/16",you will need a 1/4",and possibly a 11/16" bush.
There have been various designs mentioned on forum boards,but goshdurnit,I can't find a single one at the moment .
I seem to remember Tel had a nice simple one you could copy.
Hans.
bentprop is offline
Old 06-29-2011, 07:52 AM   #8
prof65
prof65's Avatar
Liked 13 Times on 10 Posts
Likes Given: 10
I think this is the tool bentprop is talking about.
prof65 is offline
Old 06-29-2011, 08:05 AM   #9
tel
tel's Avatar
Liked 111 Times on 106 Posts
Indeed I dew!
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 06-29-2011, 08:39 AM   #10
GRAYHIL
Liked 9 Times on 9 Posts
Hi All
.030" is not a small finishing cut! when not supported especially with HSS.
You may need to try several "spring cuts" to try and stop deflection.
Other than that all the metods described are worth a try.
Graham
GRAYHIL is offline
Selecting Tungsten Carbide Turning Inserts for a Small Manual Lathe (Long) quinette7 General Engine Discussion 20 10-01-2016 05:22 AM
turning small dia brass speedyb General Engine Discussion 12 06-26-2012 10:44 AM
Turning a Small Diameter Antman General Engine Discussion 29 03-05-2012 10:14 PM
Turning a long thin airgun barrel Dave_424 General Engine Discussion 19 12-23-2011 09:56 PM
Turning very small diameter bar mooseman General Engine Discussion 7 09-23-2008 11:44 PM
