Project of the Month built by sbdtasos
Home Model Engine Machinist > Building Them > Plans > Rotary Broach Tool Design
Old 06-26-2011, 03:15 AM   #1
excalibus
Liked 5 Times on 5 Posts
Default Rotary Broach Tool Design
Hiya people,
The other, after reading some information on rotary broach tooling and seeing a rotary broach in action, I was having my lunch at work and thought I would try my hand at designing a rotary broach tool.
In the initital rough sketch i had set out the design with a fixed MT2 Arbor (my lathe when it arrives next weekend has a MT2 on the tailstock). I had initially designed it with the arbout thread on the 1 degree angle which would put the whole tool off skew - bad idea I thought lol...
Last night I sat down and decided to redo the design after seeing that a local SIEG reseller has MT2 Arbors threaded to take a drill chuck for sale on ebay for a very decent price.
So using that as the basis for the tooling, I designed a piece that will screw onto the arbour, has a rear thrust bearing, 2 centering bearings and the tool holder held in place with a face plate.
The centre hole where the Rotary Broach cutter will be placed is drilled at a 91/89 degree angle perpendicular to the face.
I am pleased to share the drawing with you guys and feel free to comment and make suggestions on how to improve it
A couple of notes on the design, the bearing retainer plate will contain 6 or 8 screws to hold it onto the tooling body though the design does not show that clearly as I did not do a end on drawing of the face plate.
The design contains NO dimensions. it is an intial design with dimensions to be set by the available bearings, screws and the arbor (I have not purchased the arbor off ebay and so do not really know the dimensions of its backplate or the depth of its threaded face)
Also just for the record, the name Scallipus - is me... It is a name I use for a lot of gaming forums as there is another Excalibus out there on those forums lol and is the name I signed the designs with.
excalibus is offline
penni Likes This
Old 06-27-2011, 12:57 PM   #2
polygon
Liked 2 Times on 2 Posts
Default Re: Rotary Broach Tool Design
Nice sketch, keep us up to date on your progress.
rotary broach tools put square pegs into round holes
polygon is offline
Old 06-27-2011, 02:32 PM   #3
rkepler
Liked 31 Times on 26 Posts
Likes Given: 4
The trick with these is that with the tool being non-square to the work the length of the tool will move the end from center, and center is where the tool has to be. So you need to include some provision to move the tool vertically and horizontally to center it on the work.
Another thing to keep in mind is that rotary broaching is a high pressure operation. Larger tools are going to be pretty hard on the screw & nut in the smaller lathe's tailstock quill. For something like the smaller Atlas (I've got a 12x36) I would be tempted to make a quill with a lot of thread and very little travel to try and spread that force out some. For onsey-twosey it wouldn't matter much but if you were making a decent run of parts it will start to add up.
rkepler is offline
Old 06-27-2011, 03:35 PM   #4
Ken I
Ken I's Avatar
Liked 161 Times on 133 Posts
Likes Given: 4
Here's one in ACAD.dwg - zipped that I posted the other day.
Ken
I'd rather have a bottle in front of me than a frontal lobotomy.
Ken I is offline
Old 06-28-2011, 02:18 PM   #5
excalibus
thanks for that drawing ken...
I am wondering, seeing the tooltip has to be centred etc, would it be better to make it so the rotary broach holder is attached to the tool post instead of the tailstock? this would allow centring on the workpiece a lot easier I imagine... especially if setup to be used with a QCTP...
Anyone have any thoughts on that?
Old 06-28-2011, 03:43 PM   #6
Ken I
Ken I's Avatar
Likes Given: 4
Excalibus, you will notice that there are elongated holes to allow the tool to "float".
This is pretty much the design I've used to produce hundreds of thousands of holes - years of N.C. lathe production of VW Golf (Rabbit, Jetta etc) McPherson strut rods (7mm AF Allen key hole).
To set up, drill the hole and chamfer the lead in - loosen the two securing screws - bring it into the predrilled hole - float it into place under slow rotation and tighten the bolts while maintaining force - job done.
When you feed in from a tailstock you will notice a "cogging" sensation this is the broach advancing during the "slack" portion of the broaching (on say a hexagon) - the torque then generates the thrust as it turns to a corner - during the high thrust portion you aren't actually advancing the tool. Thus the broaching seems to take a lot less force than you might imagine. You are sneaking in during the slack periods and the torque is generating the thrust in between - the thrust against the tailstock is however very real - just you don't have to apply it. - Sorry its rather arkward to explain.
Even so the thrust is a fraction of simply trying to force the broach straight in.
Again for this reason - since the tailstock is non-reversible (ie the force generated can't unwind the handle) the tailstock works better than the carriage which will tend to push back - unless you are using power feed.
The drilled hole needs to be just a whisker larger than the broach - the difference in force between a whisker bigger and a whisker smaller is very large.
For standard Hex sizes such as 6mm 8mm etc. use a size drill ie 6 or 8 but grind one cutting edge slightly longer - this causes the drill to cut oversize like 8.05 - helps a lot.
I used to broach the 7mm holes in EN8 at 900rpm @ 0.05mm feed - FYI.
The broach needs to have slightly more clearance than the incline angle - (typically only more) - otherwise it will snap off - but don't use too much clearance as the broaching can start to spiral on you - particularly if your thrust bearing is going off.
This broaching principal is also used to create the external "knurled" finishes of longitudinal grooves (the circulars are turned in) such as you see on camera focus rings etc. External broaches are fairly expensive to make - typically via wire cut EDM.
Hope this helps.
This process is sometimes called a "wobbly broach" - the name's a misnomer as it doesn't really wobble (although relative to the work it does wobble) - originally a Westinghouse patent I believe.
Ken
Ken I is offline
Old 06-29-2011, 12:15 PM   #7
excalibus
Ken,
Thank you very much for that very informative description of how the broaching tool actually works, you have indeed taught me something I know the angle of the broach itself has to have clearance behind the actual tool tip and I figured this was to allow for the waste metal that is removed.
I can see why the additional size on the hole would benefit as there would be less material to remove in the 'corners' which would mean less force placed on the tailstock. Other than this, the actual force on the tailstock is the same as the force that the broach tool generates as it advances due to the torque forces placed on the tool.
Assuming each force in one direction has an equal force in the opposite direction...
Just to make sure I do fully understand...
The broach tool itself should taper back around 1.25% (1% + 1/4%) to allow clearance for the metal being cut.
The tool holder should allow the broach tool to wobble a little bit until it is aligned on the rotating part and then locked into place.
The Tailstock must be able to at least withstand the same forces placed on the tool or it will be damaged...
Just making sure I fully understand you is all ken Thanks again for your help it is appreciated...
Old 06-29-2011, 05:14 PM   #8
Ken I
Ken I's Avatar
Likes Given: 4
Excalibus - there is no waste material - it is pushed ahead of the broach and remains in the bottom of the hole - you drill the hole deeper than the broached hex by 2-3mm to accomodate this.
If you are broaching a hexagon with a slightly oversize hole the swarf is going to separate into 6 strands - with an undersize hole you are trying to turn a "tube" insideout - much greater force required.
To remove the "swarf" you re-enter the pilot drill after broaching - generally you simply leave the material in the bottom of the hole.
Don't worry about the forces on the tailstock quill - unless you find you are having to apply undue force with the handwheel.
The tool "floats" by releasing the clamping screws - the face of the broach is ultimately going to be on the same centreline as the work (the ass end of the broach obviously isn't).
Because the length of the broach may vary from broach to broach - you would have to readjust the tool holder. Once on centre the holder should be securly bolted down to the shank.
Clearance - you obviously must match the tool inclination otherwise its going to bind and via repeated flexing will be snapped off (this is what would happen if you tried to use a straight allen key as a broaching tool) - beyond that you just need a bit more () just "to be sure".
Too much clearance and you increace the propensity for the broached hole to spiral on you.
The original toolholder I used was supplied by Index in Germany who recomended dismantling and greasing of the thrust bearing every day - the hell with that - I ran it and relied on the coolant - until it broke - bearing failure starts to induce spiraling in the broached hole - normally we would pick this up because the go gauge would enter the hole easilly enough - but wouldn't reach the bottom - time to replace the bearings (maybe 10 - 20 000 parts).
The following post's tips are spot on. The undercut allows the chips to break out but can be ommitted (difficult on small holes).
Ken
Ken I is offline
Old 06-29-2011, 05:25 PM   #9
polygon
Some hole prep tips:
polygon is offline
Old 06-29-2011, 07:40 PM   #10
Ken I
Ken I's Avatar
Likes Given: 4
This from elsewhere on the forum.
Originally Posted by techonehundred
Lms actually sells some rotary Broaching bits and holders. Unfortunately they are out of stock right now. Here is the link. http://www.littlemachineshop.com/pro...3772&category=
The LMS broach has no "float" adjustment and is therefore made for one length of broach only - certainly simplifies it and mild resharpening shouldn't throw it off (at least not before the broach is indersize).
I still prefer the "float" feature.
Ken
Ken I is offline
HFT Windsor Design Tool box Tin Falcon Tools 11 12-07-2015 11:38 AM
Building KEN I Rotary broaching tool coopertje A Work In Progress 65 08-02-2014 02:41 AM
Broach set Pawn Shop find lathe nut Photos and Videos 7 02-08-2012 02:03 AM
1/4" Broach without large back needed myrickman Buy / Sell / Trade / eBay 0 09-14-2010 09:16 PM
Cutting Keyways Without A Broach Bill Mc General Engine Discussion 6 07-29-2009 12:52 PM
