Project of the Month built by Rustkolector
Home Model Engine Machinist > Showing Them > A Work In Progress > Compressed Air V8
Old 05-19-2011, 09:59 PM   #1
dvbydt
Liked 12 Times on 12 Posts
Default Compressed Air V8
This engine was started a while ago and I just had to experiment with the crankshaft as it seemed that everyone said they were difficult. I posted my attempt here :-
http://www.homemodelenginemachinist....?topic=11472.0
It turned out so well that it was good enough for this compressed air V8. The air porting was to be in and out like my Scrap Bin Motor (Thanks for all the interest) but Chuck Fellows showed how he had made his porting with a ball and spring. This is so elegantly simple that I had to copy this idea for the V8, so that meant I had to rethink my ideas. The Twin D/A Oscillator took up some of my spare time so the V8 has been on hold.
However I am back to it now. It will be 12mm bore 12mm stroke with the "camshaft" in the middle of the V driven at the same speed as the crankshaft by nylon gears at the front. On an air engine of this size, three bearings should be enough, ball races front and rear and a split plain bearing in the middle. The experimental pistons will be made from PEEK which is a high temperature plastic which turns easily is harder than nylon and does not have the same water absorption problems. It is expensive but I managed to strike lucky on Ebay.
Here is the "Proof of Concept" drawing :-
It will be made from brass bar stock. The finning is just bling. Lots of detailing to do yet, exhaust should be 4 into one both sides, so I am hoping that it will sound interesting!
Ian
dvbydt is offline
Old 05-20-2011, 12:21 AM   #2
cfellows
cfellows's Avatar
Liked 759 Times on 487 Posts
Likes Given: 3
Default Re: Compressed Air V8
Hey Ian, this looks like a great project. Glad to see someone trying a V8. Have you considered using a hollow tube cam like I used on the opposed 4? I think air leaks might be less of an issue...
Chuck
cfellows is offline
Old 05-20-2011, 09:52 AM   #3
lordedmond
Liked 4 Times on 4 Posts
peek is good stuff I use in for the piston valves on my 5 inch gauge loco's I just make the polo mint like bits from peek the rest is Stainless. make it cheaper to replace /adjust them
they just work fine but the price for 25 mm dia is ouch
Stuart
lordedmond is offline
Old 05-22-2011, 11:13 AM   #4
T70MkIII
Liked 14 Times on 13 Posts
Looking forward to watching your build, Ian.
Richard
T70MkIII is offline
Old 05-22-2011, 02:23 PM   #5
dvbydt
Chuck,
Thanks for looking in, I will need some hand holding on this one.
Air leakage.
The top half of the crankcase will have the valve shaft running in a reamed hole.
No problems on the ends. The air connection will be on a manifold bolted to the back end of the crankcase and the front will be sealed by the face of the nylon gear with a wavy washer for tension. You might check my logic on the next bit. The engine will be running as a "two stroke", this will mean that at any "TDC" two cylinders will be "firing " together in opposite banks for 180 degrees. This means that the air supply is always flowing and the only back pressure will be from the springs pushing the steel balls into the closed position. So, hopefully there will be little air leakage along the length of the valve shaft.
Stuart,
I have built up a small hoard of PEEK from looking on Ebay there are sometimes bar ends for sale, it does not seem to attract much attention. It is harder than PTFE, a bit like acrylic and machines nicely. I will experiment with it for the pistons, using PTFE as plugs at each end of the gudgeon pin (wrist pin).
I made up a conrod, just to see if I could! The screws are stainless M2 panheads. Pictures of my method will follow when I make the rest.
Ian
dvbydt is offline
akitene Likes This
Old 05-22-2011, 02:54 PM   #6
maverick
Liked 23 Times on 21 Posts
Ian- If that con rod is any indication, this will be a very nice looking engine. A two stroke with 4 into 1 exhausts
should sound great.
Mike
maverick is offline
Old 05-22-2011, 03:25 PM   #7
cfellows
cfellows's Avatar
Likes Given: 3
Very nice job on that con-rod. Did you use any jigs, CNC, or
The air leaks, if any, are more annoying than problematic. The only issue you might have is air leaking across into adjacent cylinders. My air engines are usually made to look and sound like 4 stroke IC engines and the sound of hissing air definitely detracts from that vision. I've just never been able to get that kind of valve rod to seal very well. Probably just me.
Chuck
cfellows is offline
Old 05-23-2011, 09:31 AM   #8
dvbydt
Chuck,
No jigs or CNC on this one, just made it up to see what problems there were.
I did think of using a long spool valve fitted with "O" rings to keep it air tight, but decided that it was better to keep it simple!
Thanks all for your interest, you may need patience as this one, it may take some time.
Ian
dvbydt is offline
Old 05-23-2011, 12:04 PM   #9
SBWHART
SBWHART's Avatar
Liked 194 Times on 178 Posts
Ian
What a great design, I've got a design bouncing arround in my head for a V4 that was stimulated from Chucks great designs, you section drawing as helped get a few issues clear in my mind, its going to be a good few months before I start to cut metal, so I'll be following your progress with great interest.
Stew
A little bit of clearance never got in the way
SBWHART is offline
Old 05-30-2011, 11:42 AM   #10
dvbydt
Need a bit of advice.
The simple valve shaft would only have four cutouts for feeding air into adjacent, oposite cylinders, giving me a firing order of 12567834 giving equally spaced pulses into the exhaust pipe. If I went to eight ports on the shaft, I could get the usual 18436572 for a full size V8. As I understand it the reason for the "burble" on a full size V8 is that this firing order give exhaust puffs that are 1357 and 8462 into the pipe, but in the gap between 1 and 3 firing, 8 and 4 fire, in the gap between 3 and 5, 6 fires but the is no gap between 5 and 7. My brain hurts
So is anyone able to advise me whether small model V8s "burble"?
Ian
dvbydt is offline
Compressed Air Hemi V8 T Mihelich A Work In Progress 20 11-04-2013 11:41 AM
Compressed Air Cannon Wrist Pin General Engine Discussion 7 11-22-2011 07:28 PM
Anyone use PVC for compressed air piping?? terrywerm The Shop 13 05-26-2010 06:31 AM
V-4 compressed air engine kcmillin Photos and Videos 7 01-22-2010 09:12 PM
Compressed Air Supply CrewCab Tools 3 07-06-2008 12:22 AM
