Home Model Engine Machinist > Building Them > Engines From Castings > Westbury 'Seagull'
Old 05-08-2011, 10:21 PM   #1
Charles Lamont
Liked 116 Times on 81 Posts
Likes Given: 14
Default Westbury 'Seagull'
Hello people. This is my first post in this neck of the woods. I live in the UK, West Midlands area. I have been doing model engineering for many years, but am currently tackling my first petrol engine.
It's a Westbury designed 10cc twin side-valve job, castings from Hemingway Kits 1.
You can see my progress (not very up-to-date atm, sorry) here: 2.
The latest problem I have with the design is the cam profile. As designed, the tappets are too small in diameter for
the cams, inlet in particular. As shown by plugging the dimensions into this brilliant resource 3, for a brief part of the motion, the cam is in contact with the edge of the tappet face, which seems unlikely to be good for either, or for noise (quiet is one of my criteria of success). Design dimensions are the same as the 'Seal': Base circle radius: 11/64", flank radius: 9/16", lift: 5/64" opening angle: 120°. I probably can make the tappets bigger, but ... any advice?
(1) http://www.hemingwaykits.com
(2) http://www.charleslamont.me.uk/Seagull
(3) http://modelenginenews.org/design/CamTable.php
Charles Lamont is offline
Old 05-08-2011, 11:29 PM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 952 Times on 642 Posts
Likes Given: 8
Default Re: Westbury 'Seagull'
Well you have 3 options
(1) Make a larger diameter lifter. Great if you have room.
(2) Reduce the lift of the lobe. This will change the shape of the lobe and less diameter will be needed.
(3) Make lifters with a curved surface. If the surface of the lifter that contacts the lobe has a ball end or even any kind of radius you can run a smaller diameter.
If I think of anything else I'll get back here but thats all i have right now.
stevehuckss396 is offline
Old 05-09-2011, 02:50 AM   #3
RManley
RManley's Avatar
Liked 49 Times on 31 Posts
Likes Given: 8
Hi Charles, very clear construction diary. How come everything looks so clean? I can tell this is going to be a very well made model by the time it is complete. Any ideas what you will use it for yet?
Also, where in the west midlands are you??
Rob.
Building a half size douglas motorcycle....will I be able to ride it? I just realised that a half height human is 3 years old....
Twitter: @VintageBikeShed
RManley is offline
Old 05-30-2011, 08:27 PM   #4
Charles Lamont
Likes Given: 14
Thanks. After further exploration, there is also the possibility of a larger cam angle, allowing a 'softer' cam.
I have decided I will probably increase the tappets to 9/32", which I can just get in, even with a bush.
Old 05-30-2011, 08:39 PM   #5
Charles Lamont
Likes Given: 14
Thanks, Rob
Does it? I clean parts before taking pics, but try to leave a bit of swarf around when showing setups.
Thanks again. No - no idea. I will need some kind of load to try it against, though.
Shropshire
Old 09-21-2011, 11:06 PM   #6
Charles Lamont
Likes Given: 14
Default Lapping Timing Gears
Does anyone have advice to offer on lapping the timing gears together?
Old 09-21-2011, 11:47 PM   #7
lescad
In theory you can’t lap straight involute gears because they mesh with a rolling action, therefore there is no relative movement between teeth for lapping to take place.
In practice if the gears are mounted so that one can move from side to side you can sometimes improve things. With an idler setup like the seagull you would need to lap all three gears at once (moving the idler from side to side) so unless they really need it I wouldn’t bother.
Les
lescad is offline
Old 10-14-2014, 11:38 AM   #8
Charles Lamont
Likes Given: 14
Default
One of many jobs remaining on the Seagull is a silencer (US Muffler). I have an idea what I want it to look like externally, but have little clue as to what to put inside it.
I am thinking of a drum 3/4" diameter and about 1-1/2" long, with a tangential or radial entry at one end and an axial exit at the other, both in 5/16" OD tube, all brass.
I want maximum noise reduction for minimum resistance, and would prefer to avoid a stuffing that will get clogged up, unless that is the only good way, even though it would probably be arranged for easy dismantling.
Ideas?
Old 10-14-2014, 06:29 PM   #9
petertha
Liked 222 Times on 169 Posts
Likes Given: 4
Default
In typical RC 2-stroke exhaust systems, its common to see a silencing section to the back end of tuned pipes for noise reduction & simultaneously minimize resultant back pressure. I have seen
- series of baffled chambers with offsetting entry/exit passage connector pipes or orfices
- perforated diffuser tubes like pic (kind of like a firearm principle I imagine).
- simple deflector plates in canister type mufflers (maybe a coarse version of above?)
Disregard the tuning aspect, but just mentioning the similarity of noise reduction chunk. RC fuel has oil added, so exhaust contains gunk & similarly favors an all-metal configuration vs. noise abatement stuffing as you call it.
petertha is offline
Old 10-14-2014, 06:32 PM   #10
petertha
Likes Given: 4
Default
and another pic, 4S motorcycle principle
petertha is offline
ET Westbury Side Paddle Engine kvom A Work In Progress 300 08-30-2016 10:49 PM
Westbury Heinrici Stirling engine lazylathe General Engine Discussion 14 09-26-2011 12:41 AM
westbury diagonal update imation Engines From Castings 4 09-21-2011 08:30 AM
westbury diagonalc paddle imation Engines From Castings 4 08-09-2011 08:39 AM
Dore Westbury Speedy General Engine Discussion 1 06-19-2008 03:42 PM
