Project of the Month built by driller1432
Home Model Engine Machinist > Showing Them > A Work In Progress > Finger Plate
Old 03-04-2011, 08:53 PM   #1
mariolucchini
Liked 14 Times on 14 Posts
Default Finger Plate
One of the most gratifying tasks we modelers can undertake, is the construction of our own tools....at least this is my personal way of seeing things....
A long caressed project from way back then, was the design & building of a finger plate....I just made the decision of making one for my use....since I used one of a friend of mine, I now wonder how I did without it....
I made a thorough search in the web, not finding much, but what little I learned I added to my personal needs....so here we go....
I started with the base, which I produced from a discarded PC aluminium heat sink, from which I hacksawed the fins and made a long and boring flycutting sesion....
Here it is, finally sanded and polished....the four sides are at exact 90 from each other so it can be used in my milling table and in the miniature table saw....
Notice that the upper face of the base has 3 milled "V" ways for holding different size round material...also there are 8 threaded holes which are mighty useful for holding the most used screws or bolts I mostly use in my models....these are from the smaller up....1.2 mm, 1.4 mm, 1.7 mm, 2 mm, 3 mm, 4 mm, 5 mm and 6 mm.
The bottom face of the base....
If you should want to use the finger plate on the vise, a screwed bar was devised which is applied via countersunk brass screws from below...
The pillar, made from BMS and threaded M6, the lower threaded portion is made in such a way that you can fix it to the base with just finger pressure....I intend to make a wooden box in a time to come to keep the whole safe & sound.... so the pillar must be removable......besides I love making special wooden boxes!!!!...
The pillar in place on the base...................
The clamp, made from 4 mm thick brass.......the lower ends are slightly angled so they can rest parallel to the base when in use....
The clamping knob & the special washer.............
The special washer that goes under the clamping knob, is rounded on the undernath so that it gives good grabbing power at any angle......
The adjuster screw...........Made from an M 4 bolt, with a heavily knurled brass knob, has the added finesse of using an acrylic point so as not to marr the plate's surface when tightening it..........
Here's an image of the threaded holes being occupied with an example of each bolt of different dimensions....
In a next post, I'll show the finger plate assembled and in use............
Thanks for looking.........
Mario
mariolucchini is offline
Old 03-04-2011, 09:07 PM   #2
tel
tel's Avatar
Liked 111 Times on 106 Posts
Default Re: Finger Plate
Very nice Mario, I've made a couple of these in the past, but pretty crude ones compared to this!
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 03-04-2011, 11:13 PM   #3
ref1ection
Liked 3 Times on 3 Posts
That is a very handy looking item indeed. I'm looking forward to seeing more about it's uses.
Ray
Indecision....the key to flexibility
ref1ection is offline
Old 03-05-2011, 12:48 AM   #4
Andy
Liked 2 Times on 2 Posts
Nice, Mario. A lot better than mine. Useful things, finger plates.
Andy is offline
Old 03-05-2011, 07:07 PM   #5
coopertje
Liked 55 Times on 54 Posts
Hi Mario,
Looks nice and I am curious to see what it will be used for, I have never heard of this device before.....
Regards Jeroen
coopertje is offline
Old 03-30-2011, 04:57 PM   #6
mariolucchini
Hi boys!
The finger plate is finished and a special box was made to keep it safe & sound......
The parts of the ensemble, including a special screwdriver to screw in the special base for using it in the vise....
The finger plate assembled showing some of its infinite uses.....
A brass bar in one of the "V" ways, ready to be crossdrilled....
The same brass bar in one of the corner "V" ways, ready to be filed or rectified via a grinder....
A small hinge to be filed......the clamping action of the finger plate is really powerful, when it bites.....well.................
The finished box with all its inlettings.....
The box with its contents....
The closed box.............by the way, the box was made entirely in 3 mm thick plywood....
Another homemade tool for the collection............
Cheers!
Mario
Old 03-30-2011, 05:22 PM   #7
ref1ection
Hi Mario,
Very nice work on the whole project. I know of at least one person who will be making one of these in the near future. I'm betting there will be others.
Ray
Old 03-30-2011, 07:12 PM   #8
dsquire
dsquire's Avatar
Liked 30 Times on 27 Posts
Mario
A super job both on the Finger Plate and accessories as well as the lovely case that will house it and keep all of its components together so that they are available when you want to use it. Thanks for showing it to us. I am sure that it will end up on many to-do lists.
Don
Good, better, best.
Never let it rest,
'til your good is better,
and your better best
dsquire is offline
Old 03-30-2011, 08:25 PM   #9
coopertje
This is great Mario! Suburb build (as usual) and love the box you made. Thats really putting the last point on the i!!
Looking forward to see more from your work and for sure I will build one of these too!
Thanks for showing and sharing.
Regards Jeroen
Old 03-25-2012, 02:31 AM   #10
corradini
OK - I'm just going to quit, now, and wade into the river.... I'll never be worthy.
Mario - that's a stellar piece of work. Not just the, well, 'making' of it, but the overall design, conception, thought, detail, finish -- hell, the BOX! OH - and the consideration and quality of your effort photographing, describing, and posting it for all of us!
(Uhhh, where're the detailed measured drawings and parts list and free kit offer...? >;-)
I bow to you, sir. You've made my day, just knowing there're craftsmen out there making objects that Aristotle would've said: "now that's (some Greek philosophy word meaning some kind of unattainable thing like 'quality')..."
Cheers, Andrew
corradini is offline
Finger Engine winklmj A Work In Progress 13 08-12-2011 10:07 AM
Finger Plate - Vee cutting? Omnimill Tools 14 11-03-2010 11:24 AM
Finger Brake d-m A Work In Progress 1 01-16-2010 03:36 AM
Finger Treadle zeeprogrammer Plans 3 03-26-2009 03:00 AM
Finger plate DICKEYBIRD Tools 1 10-28-2007 03:59 PM
