Project of the Month built by edholly
Home Model Engine Machinist > Whats Left? > The Break Room > Encabulator build
Old 02-27-2011, 04:27 PM   #1
Captain Jerry
Captain Jerry's Avatar
Liked 38 Times on 69 Posts
Default Encabulator build
I had not intended to publish this project yet but competitive pressures have made it necessary to advertise my intent before completion to prevent imitators and usurpers. Here is an early spec sheet and a few photos of the Retro Encabulator in development. A full build thread may follow if successful.
Specifications:
Dual double-acting flux injectors with semi-boloid chambers
arranged in an unconventional Lotus nDelta configuration.
Quad spurthing bearings to eliminate side fumbling of the spiral decomutator.
Omnidirectional phase detractors on all controls.*
Cast iron valve with hydrocoptic Marzal vanes.
Concealed Dingle arm to control sinusoidal depleneration.
Power take-off at either end via an ambifacient lunar wane-shaft.
*At this scale, no attempt has been made to emulate cardinal grammeter synchronization.
Jerry
There are things you can do and things you can't do.
I'm never sure which is which.
Captain Jerry is offline
Old 02-27-2011, 04:42 PM   #2
John Rudd
Liked 8 Times on 8 Posts
Default Re: Encabulator build
CJ,
I haven't a clue what you have described.....but it sounds/looks good
Does this item work in conjuction with a Flux Capacitor on a DeLorean?
eccentric millionaire sponsored by 'er indoors
John Rudd is offline
Old 02-27-2011, 04:45 PM   #3
Captain Jerry
I had not noticed the Giant Starfish that had wandered into the frame on the second picture above but it useful to show scale. This species is common in Central Florida and measures about 18" from across. They are a nuisance but we get use to them.
Jerry
Old 02-27-2011, 04:54 PM   #4
Captain Jerry
Originally Posted by John Rudd
CJ,
No John, it doesn't. It was originally conceived to work with long molecule Leerium but the government confiscated all supplies of Leerium in the early '70s. The design as envisioned would be suitable to use with super heated hydrogen dioxide but due to the inherent danger will more likely be powered by a high pressure mixture of 80% nitrogen and 20% oxygen
Jerry
Old 02-27-2011, 05:02 PM   #5
GailInNM
GailInNM's Avatar
Liked 279 Times on 235 Posts
Likes Given: 109
Can we assume that you will publish plans here when complete and after all patent issues have been resolved.
Gail in NM
Gail in New Mexico, USA
I would like to be the kind of person my dog thinks I am.
GailInNM is offline
Old 02-27-2011, 05:08 PM   #6
Tin Falcon
Tin Falcon's Avatar
Liked 811 Times on 646 Posts
Likes Given: 18
Funy I use almost the same fuel for my tin can turbine. Slightly less nitrogen a tad more oxygen and small amounts of argon co2 , helium neon etc and a bit of Dihodogen monoxide gas for good measure.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 02-27-2011, 05:14 PM   #7
Captain Jerry
Gail in NM
Yes. Complete plans will be posted with all relevant parts redacted. Patent application my be difficult because little (if anything) is known about the underlying operating principles.
Jerry
Old 02-28-2011, 12:57 AM   #8
shred
Liked 34 Times on 34 Posts
Won't the dingle arm need to reciprocate to provide the proper sinusoidal depleneration?
shred is offline
Old 02-28-2011, 02:36 AM   #9
Maryak
Maryak's Avatar
Liked 139 Times on 124 Posts
I don't think so, it's very difficult to mechanicalise sinusoidal reciprocation especially when you must consider the variation in depleneration which if my understanding is correct should remain constant. I think that the thread which holds the dingle arm will be strong enough and this topic together with the arm will remain gyroscopically fixed to true north effectively preventing reciprocation other than a further reply.
Best Regards
P.S. For further clarification reference should be made to "Bob's Glossary of Useless Knowledge." Of course you will require clearance from the relevant authorities before this document is accessible as it contains large amounts of sensitive as well as de-sensitising material.
Its hard to remember your objective was to drain the swamp when your up to your neck in alligators.Если вы у Тетушки были яйца, она была бы Дядюшкой
Maryak is offline
Old 02-28-2011, 02:48 AM   #10
steamer
Liked 104 Times on 100 Posts
"P.S. For further clarification reference should be made to "Bob's Glossary of Useless Knowledge." Of course you will require clearance from the relevant authorities before this document is accessible as it contains large amounts of sensitive as well as de-sensitising material."
OK THAT's where they buried Paul Harvey! I knew it!
steamer is offline
Gas Turbine build, pictorial build log. rythmnbls Photos and Videos 103 03-02-2016 09:39 PM
Build #4 P & M ???? slkride General Engine Discussion 2 04-23-2011 02:34 PM
My first build John Rudd A Work In Progress 3 10-14-2010 10:03 PM
What shall I build? Julian General Engine Discussion 6 05-02-2010 11:16 AM
I want someone to build this--- Brian Rupnow The Break Room 7 07-07-2009 11:35 AM
