Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > Tools > Calculating the speed of a bandsaw blade -- Need help
Old 01-03-2011, 09:41 PM   #1
xo18thfa
Liked 62 Times on 36 Posts
Default Calculating the speed of a bandsaw blade -- Need help
I just bought a 14" Rigid brand bandsaw from Home Depot. The spec sheet says that the blade speed is 2700 feet per minute. When I assembled the machine and turned it on for the first time, it seemed the blade was going a lot faster then 2700 FPM. I did some math and came up with a blade speed much much higher then 2700.
Request members of the HMEM board independently do the math to see if I am off. Here are the specs:
Motor speed, no load: 1725 RPM
Pulley diameter on the motor: 2"
Pulley diameter on the bandsaw shaft: 5.5"
Blade length: 93.5"
Many thanks in advance, Bob
Bob Sorenson
Las Vegas, Nevada
xo18thfa is offline
Old 01-03-2011, 10:10 PM   #2
imagineering
imagineering's Avatar
Liked 14 Times on 12 Posts
Likes Given: 10
Default Re: Calculating the speed of a bandsaw blade -- Need help
Hi Bob,
We would also need to know the Diameter of the Blade Drive wheel so you could calculate;
Motor Rpm / Pulley Ratio = Drive Wheel speed
Therefore; 1725 rpm / 2.75:1 = 627.27 rpm, (divided by, as the Ratio is geared down).
627.27 X Circumference of Driving Wheel = Blade Speed
Assuming, (for the sake of this equation), 12" diameter, (6" Radius), Drive Wheel, (which is probably wrong for this Machine)
627.27 X 37.699" (2PiR) = 23647.45Ipm (1970.6 Fpm)
This Calculation assumes no Blade slip on the Drive Wheel - The Blade length is irrelevant.
Murray
Wellington,
New Zealand.
imagineering is offline
Old 01-03-2011, 10:34 PM   #3
AR1911
Liked 2 Times on 2 Posts
Look at KMOT's gizmo he just bought from HF.
http://www.homemodelenginemachinist....?topic=12164.0
Looks like what you need for this.
AR1911 is offline
Old 01-03-2011, 10:38 PM   #4
Dan Rowe
Dan Rowe's Avatar
Liked 32 Times on 30 Posts
Likes Given: 5
Bob,
Using the logic provided by Murray and using 7" for the radius of a 14" band saw I get 2299 Fpm.
Edit: I had to fix the math.
Dan
Dan Rowe is offline
Old 01-04-2011, 12:59 AM   #5
xo18thfa
Originally Posted by imagineering
Hi Bob,
Murray
Wheel dia is 14"
Bob Sorenson
Las Vegas, Nevada
xo18thfa is offline
Old 01-04-2011, 01:12 AM   #6
MachineTom
Senior Member
MachineTom's Avatar
Liked 121 Times on 92 Posts
Likes Given: 7
Well at 2300-2700 sfpm what you need is a speed reducer of about 1:40 to cut steel. It takes all the fun out of a great deal like that, to need to come up with a speed reducer to make it work.
My Wheels don't slow me down
MachineTom is offline
Old 01-04-2011, 01:27 AM   #7
xo18thfa
I came up with 2299 now too, but in a different way. The drive wheel is geared down 1:2.75. So the drive wheel is turning 627 RPM. The drive wheel is 14" diameter or 44" circumference. That circumference makes a ratio of 1:2.125 on a 93.5" blade. So the blade is turning 295 RPM. 295 RPM x 93.5" blade = 27,582.5 IPM or 2299 FPM
I minored in math in college. It was "new math", no numbers, just Greek letters.
Bob Sorenson
Las Vegas, Nevada
xo18thfa is offline
Old 01-04-2011, 04:56 PM   #8
mklotz
mklotz's Avatar
Liked 140 Times on 260 Posts
The length of the blade is totally irrelevant. The speed of the blade is the same as the surface speed of the blade drive wheel. (Were it not so, the blade would slip on the drive wheel.)
So we have:
SFPM = wheel circumference * RPM = (44/12) ft * 627 rpm = 2299 SFPM
The fact that your calculation uses the length of the blade proves it is wrong. Were I to replace the blade with one twice as long, the SFPM would remain unchanged yet your calculation indicates that it would double.
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 01-04-2011, 09:42 PM   #9
xo18thfa
I see what I did wrong. I included blade length, then took it back out. It was a redundant step.
Thanks.
Bob Sorenson
Las Vegas, Nevada
xo18thfa is offline
Bandsaw Blade, Where do you get yours? multihobbyguy General Engine Discussion 14 03-05-2011 07:55 AM
Bandsaw blade joining John Rudd Tips and Tricks 5 11-10-2009 10:18 PM
Bandsaw cutting speed question Brian Rupnow General Engine Discussion 2 09-26-2008 07:51 PM
Give Your Parting Blade a Tune-Up, Plus Turning With a Parting Blade BobWarfield Tips and Tricks 1 05-04-2008 08:40 PM
Calculating bolt circle diameter mklotz Tips and Tricks 6 12-21-2007 05:58 PM
