Home Model Engine Machinist > The Tools and Tips > Tools > Where can I find a chuck key to fit a Ridgid drill chuck?
Old 12-31-2010, 02:44 PM   #1
cl350rr
cl350rr's Avatar
Liked 5 Times on 5 Posts
Default Where can I find a chuck key to fit a Ridgid drill chuck?
I have a Ridgid Supreme 6T33 1/2" capacity drill chuck mounted on a 2MT for my lathe. It is a rugged chuck and appears to be well made. problem is there is no chuck key for it and none of the standard sizes at the hardware stores fit it. I have done a good deal of searching online with no luck, any help out there?
thanks
Randel
Randel
the stone-age machine shop
Good, Fast, Cheap... Pick 2.
cl350rr is offline
Old 12-31-2010, 03:18 PM   #2
b.lindsey
b.lindsey's Avatar
Liked 63 Times on 62 Posts
Default Re: Where can I find a chuck key to fit a Ridgid drill chuck?
Randel,
Have you checked www.mscdirect.com ? If not look at page 1703 in the online big book. They list a lot of various sizes/series of chucks. Only problem is that you can't actually fit it to your chuck online
Bill
Edit: on second thought you could always splurge on a keyless chuck and your key problems will be history
skype: william.lindsey.iii
b.lindsey is offline
Old 12-31-2010, 04:33 PM   #3
cl350rr
cl350rr's Avatar
Bill,
thanks, the problem is figuring out what size fits the chuck. Good idea on the keyless, I just hate to see a good chuck be scrapped for lack of a key.
Randel
Randel
cl350rr is offline
Old 12-31-2010, 04:58 PM   #4
Metal Butcher
Liked 70 Times on 68 Posts
thanks
Randel
Buying a key on-line will be guess work at best. You need to test fit a key on site to be sure it fits correctly. Ridgid brand tools are mostly imported today, so its not likely they will have a replacement key available unless the chuck is marked 'made in USA' and they can tell you the name of the manufacturer, and they might be able to supply you with the correct key, its not very likely though..You might be better off putting your effort and money towards a new keyed chuck, or a new key-less chuck.
Chuck quality has gone up at the same time that prices have gone down. One example is in the link below.
http://www.shars.com/products/view/6...Drilling_Chuck
-MB
In Constant Pursuit Of Perfection
Metal Butcher is offline
Old 12-31-2010, 05:04 PM   #5
mklotz
mklotz's Avatar
Liked 140 Times on 260 Posts
How about trying one of these...
http://www.harborfreight.com/four-wa...-key-1745.html
Regards, Marv
Home Shop Freeware
http://www.myvirtualnetwork.com/mklotz
mklotz is offline
Old 12-31-2010, 06:10 PM   #6
rcmadness
Liked 8 Times on 8 Posts
Homedepot sells Rigid tools and they might have a chuck key that would fit. If you have a Home Depot in your area you could carry the chuck in and check for a key.
Just a thought.
One hobby that provides stuff for all the other hobbies.
rcmadness is offline
Old 12-31-2010, 06:20 PM   #7
cl350rr
cl350rr's Avatar
Thanks for the replies,
I've been to home depot, lowes, sears and northern equipment. none of the off the rack keys will fit. I even tried the "four keys in one" and none of them fit.
I have other chucks, I am not in need of a new one. Just don't want to trash this one. it is at least 20 years old and a reasonably well made chuck. I actually use it quite often I just don't like what I have to do to tighten it.
Randel
Randel
cl350rr is offline
Old 12-31-2010, 07:21 PM   #8
jonesie
Liked 11 Times on 11 Posts
if you are not in a hurry why not just get on ridgids website and email them with the chuck number , and have them send you one. jonesie
jonesie is offline
Old 01-01-2011, 01:19 AM   #9
Stan
Liked 31 Times on 31 Posts
I took an oddball chuck to a local machine tool supply house and the counterman went through a box of keys until he found one to fit.
Stan in Leduc, Alberta, Canada. 53.40NĀ* 113.5W
Old, but still on the right side of the grass.
Stan is offline
Drill Chuck Arbors kendo General Engine Discussion 7 01-03-2011 11:08 AM
Drill chuck krv3000 Tools 6 08-27-2010 10:12 PM
Mounting a drill chuck TarheelTom General Engine Discussion 13 08-20-2010 05:50 AM
LFA 400 drill chuck playing up njl General Engine Discussion 4 07-24-2010 10:06 AM
Drill chuck removal Bill S Tips and Tricks 4 12-28-2009 08:20 PM
