Project of the Month built by TonyM
Home Model Engine Machinist > Building Them > General Engine Discussion > Little machine shop high torque mill ?
Old 11-10-2010, 03:56 AM   #1
BMyers
Liked 9 Times on 9 Posts
Default Little machine shop high torque mill ?
I have a Van Norman #12 Mill. Great mill for metal removal but the lack of a quill sucks. I am thinking of adding the Little Machine Shop High Torque mill to the collection for X-Y drilling and light milling. Does anyone have this machine ?
BMyers is offline
Old 11-10-2010, 10:01 AM   #2
steamer
Liked 104 Times on 100 Posts
Default Re: Little machine shop high torque mill ?
Nice to have a fellow VN owner here....it is no fun without the quil...but "Norm" makes up for it in other ways.....Best of luck to you with the Hi Torque.
steamer is offline
Old 11-18-2010, 03:38 PM   #3
ChrisB
Liked 7 Times on 7 Posts
Hi,
Yes I have the 'High Torque' Mill. It's actually a Sieg SX2, really just an X2 mill with a brush-less motor. (Unless I am looking something totally different on the LMS site).
There is a good review here: http://www.mini-lathe.com/Mini_mill/...%20SX2/SX2.htm
I have to be fair that this is the first Mill I have ever owned or operated, so my knowledge and feelings should be taken as such. The machine is far from perfect out of the factory but workable with a little time. I have had some very pleasing results with the mill, and now after a little bit of work all I have to complain about is the frankly terrible action of the Z axis. The air spring conversion is a must I would say for a drilling rig. IMHO.
More than happy to discuss firther if you wish, and if I am even talking about the right machine
Chris
ChrisB is offline
Old 11-18-2010, 05:37 PM   #4
Kermit
Guest
Posts: n/a
Check out the same version of mill at www.micromark.com. I believe the motor power is the same as well. They also have a slightly smaller mill they now started selling this year. I got one of the X2 clones they sell, and they seem to be the cream of the chinese crop, so to speak.
Old 11-19-2010, 12:26 AM   #5
narrowgauger
Liked 5 Times on 4 Posts
the Micromark machine is NOT the same as the LMS version of the Sieg SX2 so take care when comparing same.
we are agents for the Sieg SX2 in Australia. our experience with the SX2 (almost identical to the LMS version) has been excellent particularly considering that Sieg have also upgraded their overall machining on the this new machine. In our humble opinion the SX2 is now the best value for money on the market for a hobby machine with good general capacity.
Whilst still not in the Proxxon FF400 bracket the Sieg SX2 delivers great value and machining capacity. The LMS shop unit has the added benefit of a longer table bed, compared to the Micromark unit.
when considering the Sieg unit please ensure that it is a SX2, not an X2 since there is a world of difference between these models. The SX2 has a very good servo motor installed with an upgraded control board. However it costs more than the X2, which is still on offer by many suppliers, but worth every cent of the difference.
have fun with your new machine when you buy it
Bernsrd
narrowgauger is offline
Old 12-06-2010, 03:51 AM   #6
BMyers
Bernsrd
Can you elaborate on the upgraded overall machining ? I assumed the SX2 was just and X2 with the brushless motor. What other differences are there ?
BMyers is offline
Old 12-06-2010, 04:06 PM   #7
winklmj
Liked 12 Times on 12 Posts
SX2 review:
MM sells both the X2 and the SX2 (and the old 7x14 and newer 7x16 lathe as well).
Mike
winklmj is offline
Old 12-07-2010, 03:07 AM   #8
narrowgauger
BM
in response to your question, we placed a new X2 and a new SX2 side by side and did a direct comparison.
we found that all the changes noted in the detailed review of the SX2 (see above post) were correct. However we also found that Sieg (certainly on our samples) had taken considerably more care with the following components:
- quality of milling to the ways, which were much more accurate on the SX2 and well within accepted tolerances on all measurements;
- the lead screws threads were better machined and consistent in pitch in comparison;
- backlash on all axis was excellent as a result of the better detailing, particularly the Z axis where the rack / pinion positioning was excellent;
in all we found that Sieg had taken much more care with the SX2 compared to the X2. this was particularly important insofar that both machines had been received from China in the same shipment. Either Sieg is using a different production line for the SX2 or they have taken steps to further improve their accuracy.
Compared to our "standard" Proxxon machines, the Sieg SX2 is not becoming a valid contender for quality and capcity to perform.
As the full review notes, the Servo motor has all the torque you would ever need for a machine this size.
Have fun
Bernard
The Model Works Australia
Old 12-08-2010, 02:40 AM   #9
BMyers
The LMS mill arrived today but since it is only 6 degrees in the shop I didnt get more than the mill unpacked and a quick once over. I am eager for some warm weather to clean it, oil it, tram it and make something.
BMyers is offline
Old 12-13-2010, 12:57 PM   #10
Malefic
Liked 2 Times on 2 Posts
I do have one sieg SX2, and I'm happy with it so far...not perfect, I've upgraded mine with the sieg power feeder and it does make machining more enjoyable, but the build quality of the power feeder it's not up with the mill, it's a terrible design also have the RPM meter which it's nice and waiting for gas strut from LMS....when all complete will make a really nice hobby mill. I cant compare it with the old X2, but i also own a sieg SX1L from arc euro trade, and the SX2 wins hands down, shame it does have considerably less travel than the "small" SX1L.
Malefic is offline
Hi torque solid head mill dreeves Tools 10 04-22-2015 11:18 PM
High speed spindle attachment for my mill gbritnell Machine Modifications 7 03-26-2010 04:11 AM
Fitting an Air Spring from Little Machine Shop to X2 Mill tmuir Machine Modifications 2 01-01-2010 01:51 AM
Do you have to use high tensile bolts in mill clamps? spuddevans General Engine Discussion 21 10-25-2008 06:01 PM
Little Machine Shop rake60 The Break Room 1 07-18-2007 03:34 PM
