Home Model Engine Machinist > Building Them > General Engine Discussion > 220V single phase motor install and wiring
Old 10-24-2010, 11:18 PM   #1
steamer
Liked 105 Times on 101 Posts
Default 220V single phase motor install and wiring
Hello all,
I am putting a new motor in my VN-12 mill.
2 HP single phase 220 volt.
The old starter wiring and blocks are shot...50+ years old
I am starting pretty much from scratch
The mill uses 220V 4 wire ( L1, L2, N, and ground)
It also has a 120 volt X axis feed motor that I am rewiring the controls for.
I could use the advice from some of you sagged electrical veterans.
I need soup to nuts here.....
The new motor is 7 wire with an internal thermal overload.
Any help would be appreciated!
steamer is offline
Old 10-24-2010, 11:31 PM   #2
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 952 Times on 642 Posts
Likes Given: 8
Default Re: 220V single phase motor install and wiring
Post a photo of the name plate and any diagram you may have. Sometimes there are wiring diagrams in the peckerhead (little junction box on the motor). The more info the better.
stevehuckss396 is offline
Old 10-24-2010, 11:48 PM   #3
steamer
This would be the high voltage side, on the right
7P2 is the brown line and is the thermal overload wire....which appears to be isolated in this application.
I need this broken down for dummies here....so be gentle....
steamer is offline
Old 10-25-2010, 12:03 AM   #4
Dan Rowe
Dan Rowe's Avatar
Liked 32 Times on 30 Posts
Likes Given: 5
Dave,
If you have a 220 4 wire supply the colors should be black red white and green. Which are hot hot neutral and ground in that order.
The voltage should be 220 between red and black and 120 from red or black to neutral and ground.
The red and black are L1 and L2 sp they go to the high voltage combination which leaves one wire not connected to anything.
The 120 circuit can be made with either red or black and white and green goes to the motor frame.
Is there a motor controller in the circuit or a simple on off switch?
Dan
Dan Rowe is offline
Old 10-25-2010, 12:04 AM   #5
stevehuckss396
Senior Member
Likes Given: 8
I assume the mill has a drum switch for forward and reverse. Does the switch have a similar drawing?
We are off to a pretty good start.
Old 10-25-2010, 12:06 AM   #6
steamer
Hi Dan,
I read and understand all you have said.
That part I know....What controls I need to put in between is the tougher nut to solve...no experience here.
steamer is offline
Old 10-25-2010, 12:11 AM   #7
steamer
I have a new drum switch which I purchased from MSC.
I don't have anything else to speak of. ALL NEW!
The drum switch is a ACI CB0170034PL2.
As I see it I need 5 wires coming out of the motor.
I spent some time with a ohm meter on the switch and I can't get it figured out so it works. What I want ...really...is to have a completely dead motor with the drum switch in the off position ( no hot legs)
I would like to keep it as simple as possible, but I am afraid I need a relay.
I am hoping you guys can set me straight.
I'll try to get a diagram for the drum switch...got to get my son down for the night.....
steamer is offline
Old 10-25-2010, 12:13 AM   #8
steamer
Hi Dan,
The mill is reversing, and I very rarely do use it in reverse. I would like to keep that feature.
steamer is offline
Old 10-25-2010, 12:38 AM   #9
stevehuckss396
Senior Member
Likes Given: 8
There should be some sort of paperwork with the new switch. See if you can dig it up and i'll check back tomorrow after work and see if I can draw something up if someone hasn't come up with something for you.
Old 10-25-2010, 09:18 AM   #10
steamer
Hi Guys...I'll get the diagram after work...Thanks Guys!
steamer is offline
Single Phase Motor Chatter velocette The Break Room 6 04-04-2012 09:04 PM
Variable speed for single phase motor? lazylathe Machine Modifications 17 04-23-2011 03:00 PM
120V to 240V Single-Phase motor conversion JorgensenSteam General Engine Discussion 4 10-29-2010 03:00 AM
MILL PURCHASE -- SINGLE PHASE VERSUS THREE PHASE QMAN56 General Engine Discussion 5 01-31-2010 09:47 PM
Converting Single Phase Power to Three Phase wareagle Machine Modifications 19 11-10-2008 01:50 AM
