Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > miniature boring bars
Thread Tools Display Modes
Old 09-16-2010, 09:30 PM   #1
hobby
Liked 56 Times on 54 Posts
Default miniature boring bars
Hi guys,
I haven't tried this yet, but I want to start building smaller projects, which require smaller tooling for my benchtop tools.
From my experiance in reaming and boring a hole with a boring bar, in my lathe, I find that I can get a more acurate cylinder bore with a boring bar.
Not to say that my reamers don't do a good job, but it seems like if the preliminary hole is off a bit, from drilling, that a reamer in the small diameter sizes, don't do a good job in correcting it unless I run it in and out like a boring bar, the finioshed hole diameter is of course larger, but a reamer in the small dia, seems to have some flex to it that will follow a crooked drilled hole.
With all that said, I was thinking of making very miniature sized boring bars, without having to purchase them.
I was thinking about using a 1/8" , 3/16" and a 1/4" dia. reamers, and modify them to work as miniature boring bars.
These 3 sizes would take care of the smallest cylinder bores I would be working with.
The way this would be done, is I would grind back all the flutes except one, and this one flute would be ground back top and bottom, leaving a small bit unground, at the very front, past the tapered front, wich would act as the cutter.
Would this work?
Any suggestions on why this would not work?
Thankyou.
hobby is offline
Old 09-16-2010, 09:36 PM   #2
tel
tel's Avatar
Liked 105 Times on 101 Posts
Send a message via Yahoo to tel
Default Re: miniature boring bars
Sounds like it would work OK but you would save yourself a power of money and work by making them out of cut-off, good quality, Allen Keys.
Tel
I come from Australia
That's my native land
Where a bird in the bush
Is worth two in the hand
tel is offline
Old 09-16-2010, 10:55 PM   #3
hobby
Thanks Tel,
That sounds like a good idea too.
I'll have to look into that as well, when the time comes to make a miniature boring tool.
hobby is offline
Old 09-16-2010, 11:02 PM   #4
Blogwitch
Liked 174 Times on 160 Posts
Old blunt drills are even easier to work with, just grind a flat angle across the front and they are ready to use.
Bogs
Blogwitch is offline
Old 09-17-2010, 01:08 AM   #5
George_Race
Liked 16 Times on 16 Posts
Bogs:
Can you explain what you mean by a "flat angle" across the front.
I need some small boring bars and have a lot of old HSS steel drills.
George
George_Race is offline
Old 09-17-2010, 04:12 AM   #6
hobby
Bogs
Thanks Bogs
the only thing I would be concerned about is the flexation due to the deep flutes in a drill, versus the flutes cut into a reamer.
however , old thrown out endmills may work too, they may be mor rigid, plus theres a second use for them as well.
hobby is offline
Old 09-17-2010, 09:01 AM   #7
Blogwitch
George,
Not a very good C-o-C, but I hope it explains it.
You only need to grind one flat surface straight across the drill, with the two outer cutting tips horizontal, slightly angled to one side and with the nose of the drill angled slightly upwards. That, when ground, will use the left hand cutting edge as the tip of your boring tool. If you don't understand, I will attempt to take pictures to explain what the angles are about.
Hobby,
I have used these drill types to bore out tiny holes, and because of the rigidity of the flutes, they will flex less than a normal boring bar of the same size. The best way to hold them is to put them into a pin chuck and then hold the pin chuck in your toolpost. They are mounted a couple of degrees off straight in, to present the cutting tip to the bore wall.
For boring above 5mm up to where my normal boring tools take over, I use these 'German' type boring bars, the smallest set. Also by making a small adaptor, I fit them into the boring head of my mill for those small precision bored holes.
http://rdgtools.co.uk/acatalog/TOOL_...ING_HEADS.html
I hope this helps
Bogs
Old 09-17-2010, 01:30 PM   #8
George_Race
Thanks Bogs, you little drawing made it real clear.
Should make it real easy for those very small bore jobs.
George
Old 09-17-2010, 03:59 PM   #9
dieselpilot
Liked 92 Times on 84 Posts
I've made boring tools from drill rod. It doesn't take much relieving to make something that works. The solid shank is pretty stiff, but I've never used it on steel. I also have a purchased indexable carbide boring bar for .210 min ID holes. I prefer to use the purchased tool.
dieselpilot is offline
Old 09-18-2010, 12:45 AM   #10
gjn
Liked 2 Times on 2 Posts
The latest issue of Model Engineers Workshop (16 has an article on this subject which may assist you
gjn is offline
Ridigity of boring bars.. Hal Tips and Tricks 22 11-11-2010 11:27 PM
home made solid carbide miniature boring bar ttrikalin Tools 1 11-05-2010 02:30 PM
Carbide shank boring bars/1" reamer/Refractometer SmoggyTurnip Buy / Sell / Trade / eBay 0 03-07-2010 12:54 AM
How to use sine bars rickharris Links 28 08-03-2008 10:24 PM
Small boring bars Alex Tools 7 12-22-2007 04:31 AM
