Project of the Month built by Rustkolector
Home Model Engine Machinist > HMEM > Introduction > The Holly Buddy 2,5 cc model diesel engine
Old 08-15-2017, 07:40 PM   #51
modelmotor
Liked 146 Times on 86 Posts
Likes Given: 11
Default
Hallo Model Engine Friends
I just finished the lapping from my cilinderliner.I am not such a good photograph that i can show you all the lapping results in the
right way so i dediced to make just a couple of extra photos from that job and no more.
Hopefully you like the lapping results however i must admit that making pictures from such a critical work in my own is rather difficult you will understand.
many greetings from modelmotor-Gerard-The Netherlands-Europe.
cilinder lappen 001.jpg   cilinder lappen 003.jpg   cilinder lappen 004.jpg   cilinder lappen 009.jpg
modelmotor is offline
minh-thanh Likes This
Old 08-20-2017, 07:18 PM   #52
modelmotor
Likes Given: 11
Default
I have made a certain number of pictures telling a bit from the lapping story step by step.
I do it on my way and the past showed me that it can be done as shown on the pictures ,but be very carefull and try the fit very often as well as the size of the part(s).
I hope you like my pictures as well.
zuiger cilinder lapping plus extra engine pictures 005.jpg   zuiger cilinder lapping plus extra engine pictures 006.jpg   zuiger cilinder lapping plus extra engine pictures 007.jpg   zuiger cilinder lapping plus extra engine pictures 008.jpg   zuiger cilinder lapping plus extra engine pictures 009.jpg
zuiger cilinder lapping plus extra engine pictures 010.jpg   zuiger cilinder lapping plus extra engine pictures 011.jpg   zuiger cilinder lapping plus extra engine pictures 012.jpg   zuiger cilinder lapping plus extra engine pictures 013.jpg   zuiger cilinder lapping plus extra engine pictures 014.jpg
zuiger cilinder lapping plus extra engine pictures 015.jpg   zuiger cilinder lapping plus extra engine pictures 018.jpg   zuiger cilinder lapping plus extra engine pictures 019.jpg   zuiger cilinder lapping plus extra engine pictures 021.jpg   zuiger cilinder lapping plus extra engine pictures 022.jpg
demaic Likes This
Old 08-20-2017, 09:11 PM   #53
Mechanicboy
Mechanicboy's Avatar
Liked 170 Times on 134 Posts
Likes Given: 229
Default
Smear with Autosol on piston and grind carefully into the cylinder while you are pushing the piston into cylinder to create tapered cylinder.
To test the fit is correct:
Dry piston/cylinder = Tight to push piston into cylinder.
Oiled piston/cylinder = Loose in BDC and tight in TDC ---> tapered cylinder.
Jens Eirik, Bergen in Norway :)
Mechanicboy is offline
modelmotor Likes This
Old 08-21-2017, 12:31 PM   #54
modelmotor
Likes Given: 11
Default
Hallo Jens Erik,
Thank you very much for your contribution on my thread about making the best fit for my piston into the liner,
It's very pitty that i have n't made a short movie of my work.It's only showed in the pictures,but pictures can also tell the story.I made my piston/liner fit the same way as you described only not using Autosoll ,but a drop of very thin sewing-machine oil which i clear out/smear around the piston with my finger just one tiny little drop not more.
I take measurements by trying to push the piston into the liner each time a work which is very time consuming,but as you can see Jens i am making some progress with the fit of the piston which must be very tight indeed.
I appreciate your own metal working as well. Thank you very much for your advices in this case.
Old 08-21-2017, 09:30 PM   #55
Mechanicboy
Likes Given: 229
Default
Originally Posted by modelmotor View Post
Hallo Jens Erik,
You can use tallow instead sewing-machine oil/Autosol as englishmen did with their model engines in old days.
Jan David-Andersen (norwegian production of D-A model engine) wrote in the book "Dieselmotor for modell-fly, bt og bil", 1945 ("Diesel engine for model aircraft, boat and car"): In a deep cup, make a mixture of grinding paste and thick oil and let the mixture lay as the coarse grains sink to the bottom of the cup. The top layer of grinding paste is suitable to create fit between cylinder / piston.
Old 08-22-2017, 02:05 PM   #56
modelmotor
Likes Given: 11
Default
Hallo Jens Erik
Thank you for your contribution on my thread about making the Holly Buddy 2.5 cc model diesel engine.The use of tallow oil might be also a good solution however i never used it.There are also people using sour/acid free very thin Gun oil as a way of lubricating during the lapping process.This type of oil can be used by the lapping process in a very low quantity,but that will be the same when using another kind of thin lubricating aditif.
Your book looks very interesting to me.I got several old model engine books from my father who already passed away for 26 years ago now.
The old model engine builders very often do have great ideas about all kinds of making sudden model engine parts and the lapping from critical parts like a piston and a cilinderliner is one of those very interesting jobs to do.One of the books i owned from my father is tittled:"Benzinmotoren fr Flugmodelle und ihr Selbstbau". The Editor/Publisher from this model engine book is Mr.A.Felgiebel. I think that you already have heard from this name in model engine circles.
Thanks again for helping me.
many greetings from: modelmotor-Gerard-The Netherlands-Europe.
Old 08-23-2017, 08:54 PM   #57
Mechanicboy
Likes Given: 229
Default
Hallo Jens Erik
Yes, i had read about this model engine builder Alfred Felgiebel from this link
https://kleinstmotoren.lima-city.de/histori4.html
demaic Likes This
Old 08-24-2017, 07:10 PM   #58
modelmotor
Likes Given: 11
Default
Hallo Jens Erik
Yes this book is as a souvenir for me i received it from my father died already years ago.The book contains drawings and lot's of technical writtings to make a model engine yourself.I have restored the book it was in a terrible state through the years now it looks in some way Ok to me,but the front cover is still damaged,but after the restore not as much as before.
Dietmar Kolb from www.kleinstmotoren.de is a man i know from some years ago now. I have placed my model engine videos and pictures on his website.So when you are visiting his website place look after videos and pictures under my name.
Many thanks for your sympathic informations.
Old 08-31-2017, 07:30 PM   #59
modelmotor
Likes Given: 11
Default
A Cast Iron contra piston was made which i lapped into the liner for a good fit and seal so no leakage and very good strong compression.Each time you can hear a very strong and loud plop,plop when turning the propellor over.I have assembled the engine after that work and now i will do some refinements outside the motor to look it still much better.
I am real happy with my engine designed and already made by Ed Holly.He made a lot of work from his Holly Buddy 2,5 cc diesel engine thread to show us the right way to built a good model diesel engine at special the Toolings for lapping and Honing and the lot of advices were very welcome to look after each time during the built.
Many greetings from modelmotor-Gerard-TheNetherlands-Europe.
completing liner lapping contra piston final assembling 001.jpg   completing liner lapping contra piston final assembling 002.jpg   completing liner lapping contra piston final assembling 003.jpg   completing liner lapping contra piston final assembling 006.jpg   completing liner lapping contra piston final assembling 007.jpg
completing liner lapping contra piston final assembling 008.jpg   completing liner lapping contra piston final assembling 009.jpg   completing liner lapping contra piston final assembling 010.jpg   completing liner lapping contra piston final assembling 011.jpg   completing liner lapping contra piston final assembling 012.jpg
completing liner lapping contra piston final assembling 013.jpg   completing liner lapping contra piston final assembling 017.jpg
4
People Like This
Old 09-02-2017, 10:07 AM   #60
modelmotor
Likes Given: 11
Default
Hallo Model Engine Friends,
It's Saturday at around 12 P.M. in the morning.Here are the first photos made from my Holly Buddy 2,5 cc model diesel engine finished.I am very happy with the result and the first plopping sounds the piston makes in the liner.It all feels very good so if this engine will be a slow or fast running engine will be expected as soon as my fuel will be at home for making a real "diesel brew" of it so till that time the best for all of you and enjoy your wonderfull hobby by making all kinds of model engines.
Many greetings from modelmotor-Gerard-The Netherlands-Europe.
Finished Engine!!! 001.jpg   Finished Engine!!! 002.jpg   Finished Engine!!! 003.jpg   Finished Engine!!! 004.jpg   Finished Engine!!! 005.jpg
Finished Engine!!! 006.jpg   Finished Engine!!! 007.jpg   Finished Engine!!! 008.jpg   Finished Engine!!! 009.jpg   Finished Engine!!! 010.jpg
2
People Like This
how i made the B.J.Cicada Model Diesel Engine modelmotor Photos and Videos 32 10-24-2015 07:49 PM
Monster-Sized, Model Diesel Engine BronxFigs Plans 4 05-08-2015 10:40 AM
making a Boll Major 4,4 cc model diesel engine modelmotor A Work In Progress 24 03-01-2014 08:38 PM
Diesel Engine Model - run off biodiesel? mnbylcr2 General Engine Discussion 7 08-31-2013 09:53 AM
Das Boot Diesel engine model? ieezitin General Engine Discussion 6 02-14-2010 04:15 PM
