Project of the Month built by gbritnell
Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > Fusion360
Old 10-30-2017, 08:59 AM   #11
TonsOfPaper
Default
Have you checked up if your video drivers is up to date?
TonsOfPaper is offline
Old 10-30-2017, 11:18 AM   #12
dalem9
Liked 76 Times on 57 Posts
Likes Given: 99
Default
Have you added an add blocker ,I had that same problem about a month ago myself .
If you think you can,you can .If you think you can't you can't ! Where there's a will there's a way !
dalem9 is offline
Old 10-30-2017, 11:22 PM   #13
gld
gld's Avatar
Liked 27 Times on 18 Posts
Likes Given: 126
Default
Problem solved. I had to boot the computer in safe mode then download Malwarebytes. Malware found 140 items that needed to be deleted. After deleting those items everything is back to normal thank goodness.
Gary Davison Tarkio, Missouri
gld is offline
dalem9 Likes This
