Project of the Month built by mayhugh1
Home Model Engine Machinist > The Tools and Tips > Tools > Removing machine tags
Old 09-11-2017, 07:30 AM   #1
kiwi2
Liked 72 Times on 42 Posts
Default Removing machine tags
Hi,
I'm in the process of restoring an old lathe and I've got to the stage where I want to remove the name tags and data labels in preparation for painting.
They are made of thin aluminium sheet appear to be held in place with round headed aluminium nails.
There was one tag which was so mangled that it won't be going back on so I used it to see how to best remove others.
I couldn't get a grip on the heads of the "nails" with a pair of pliers so I tried levering them off with a slim cold chisel. It worked OK but the plate ended up badly bent.
Is there a trick to getting them off?
If all else fails, I suppose the best way of removing them without damaging the tags would be to drill them out.
Also, does anyone know the correct term for the "nails" and where to get them from?
Thanks,
Alan C.
kiwi2 is offline
Old 09-11-2017, 08:42 AM   #2
Cogsy
Cogsy's Avatar
Liked 432 Times on 332 Posts
Likes Given: 413
Default
Are they not just blind rivets?
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 09-11-2017, 10:57 AM   #3
TonyM
Liked 56 Times on 23 Posts
Likes Given: 27
Default
We always used to use hammer drive screws on labels. The only way to make a good job is grind a small flat on the head, carefully centre mark and drill out. If you are replacing with the same you can usually measure the drill size from the end of the new screws
This is what you need to look for https://www.bolt.com.au/0g-316-grade...l-p-16242.html
TonyM is offline
Old 09-11-2017, 12:43 PM   #4
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 100 Times on 91 Posts
Default
I think these are called "drive rivets," although I may be mis-remembering today.
Anyway, Keith Rucker (YouTube: Search "Keith Rucker" or "Vintage Machinery") talks quite a bit about them as he has restored a LeBlond lathe and is currently working on a 16-inch Monarch lathe, as well as other old machinery. He also demonstrates techniques to restore and repaint old tags so that they are readable.
--ShopShoe
ShopShoe is offline
Old 09-11-2017, 01:25 PM   #5
bazmak
BAZMAK
Liked 840 Times on 493 Posts
Likes Given: 687
Default
They are usually hardened. I have had success using a wood chisel under the
the tag and rivit head.Doesnt do the chisel asny good and usually knackers the label
bazmak is offline
Old 09-11-2017, 09:00 PM   #6
blockmanjohn
Liked 1 Times on 1 Posts
Default
The information plate on the gearbox of my South Bend 9A had the same type of round headed fastener. It turned out to be a threaded pin that was hammered into place. To remove it I cut a slot in the head with a Dremel tool and simply backed it out with a screw driver. Very easy. This may or may not be your situation, but it might be worth a try. John.
blockmanjohn is offline
Old 09-12-2017, 06:24 AM   #7
kiwi2
Default
Hi all,
Thanks for the comments and suggestions. I tried cutting a slot and screwing the fastener out with no joy. The fasteners on my lathe seem to be made of aluminium with tapered shafts and are hammered in.
I ended up using a 1/2" wood chisel as John suggested. The trick is to use the corner of the chisel and drive it across the head near its base but clear of the tag. When the chisel has bitten into the aluminium the chisel is then angled while continuing to tap it so that the head is forced upwards. When it was clear of the tag by a millimeter or so, I gripped it with the end of a big pair of pliers and twisted and pulled at the same time which extracted the fastener. I've managed to remove all three tags with minimal damage to them.
I'm not sure what I'll use to reattach the tags. The holes are 3/32" diameter. If I can find a similar product I'll use that otherwise I'll either tap them for screws or drill the holes out to 1/8" and use pop rivets.\
Alan C.
kiwi2 is offline
bazmak Likes This
Old 09-13-2017, 05:22 PM   #8
Wizard69
Liked 174 Times on 156 Posts
Default
Drive rivets (what we call those things around here) are stocked by most of the larger hardware stores. Think McMaster Carr here.
There is a possibility that the tags where removed before, sometimes these machines get rebuilt several times before the current owner takes possession. If so the rivet holes could be worn out requiring upsizing or replacement with something else.
As for something else, drilling and tapping can work but the screw heads can be a bother in some locations.
One modern consideration is glues or sealants. Ive actually have had success with Loctite thread locker for smaller labels and tags. You just need to secure said label in place until the Loctite sets up. Super Glue is another possibility. I haven't done large labels this way, think pushbutton size or a bit larger. I do know that the loctite worked where other glues failed.
Then you have the RTV like sealants which can have a tremendous grip and should be considered to be more permanent than drive rivets.
So depending upon the location and the labels size you really have lots of options for reattachment. Id go with the original method if at all possible.
Wizard69 is offline
Old 09-13-2017, 06:04 PM   #9
Mike1
Mike1
Liked 19 Times on 6 Posts
Default
Hammer drive screws are what you need they come in all sizes and material
https://www.toolfastdirect.co.uk/aca...ound_Head.html
Mike.
Smaller amounts should be obtainable.
Mike1 is offline
Old 09-14-2017, 06:28 AM   #10
kiwi2
Default
Thanks Wizard and Mike. At least I know what they are called now. I'll try the local fastener suppliers tomorrow.
Alan
kiwi2 is offline
Removing a flywheel from its crankshaft. Tony Bird A Work In Progress 8 07-13-2017 05:31 PM
Removing old download files cfellows The Break Room 0 10-05-2015 03:57 PM
Removing a broken drill bit? wespete66 General Engine Discussion 30 11-14-2014 09:00 PM
Removing a broken tap va4ngo General Engine Discussion 39 01-25-2010 09:31 PM
Removing taps from aluminum gr8life Tips and Tricks 2 01-20-2008 03:05 PM
