Home Model Engine Machinist > Showing Them > A Work In Progress > Small V8
Old 01-15-2018, 09:24 PM   #1331
GRAYHIL
Liked 9 Times on 9 Posts
Default
Hi all
Anyone know what the valve clearance is?
I am not ready for it yet just getting facts together.
Many thanks
Graham
GRAYHIL is offline
Old 01-16-2018, 03:59 AM   #1332
Cogsy
Cogsy's Avatar
Liked 486 Times on 378 Posts
Likes Given: 477
Default
I would say as long as it has some clearance then it will be fine. It's not like it's going to run for extended periods where everything gets thoroughly hot, expands and clearances reduce. If you make it to large you're reducing your cam lift and duration, which won't affect it all that much anyway - again it's not like full size where we're chasing maximum power. So I'd just set them so it has a little clearance by feel and call that good enough.
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 01-19-2018, 10:12 AM   #1333
GRAYHIL
Default
Thanks Al
Graham
GRAYHIL is offline
Old 01-21-2018, 11:17 AM   #1334
GRAYHIL
Default
Hi All
Do the valve cages sit flush with the head cylinder cut out? or are they .017 below.
Depth of recess in head .397 length of cage .38
They do not look right when .017 below and would presumably restrict gas flow as valve head would only just fit in, waiting loctiting so answer would be appreciated.
Graham
GRAYHIL is offline
Old 01-21-2018, 03:58 PM   #1335
stevehuckss396
Senior Member
stevehuckss396's Avatar
Liked 944 Times on 636 Posts
Likes Given: 8
Default
They should be .017 below. When the valve is installed it will be flush with the surface or real close to flush. There is plenty of lift and duration in the cam to get the cylinder filled up.
stevehuckss396 is offline
Old 01-22-2018, 05:58 PM   #1336
GRAYHIL
Default
Steve
Thanks for your reply, you are most helpful.
Graham
GRAYHIL is offline
Small EDM job gbritnell General Engine Discussion 10 06-29-2011 05:41 PM
How small is YOUR distributer? kcmillin General Engine Discussion 8 10-25-2010 10:44 PM
A small X2 mod Bill S Machine Modifications 4 02-07-2010 01:42 AM
Small Mills FireReplica General Engine Discussion 13 08-10-2009 09:10 AM
Small gas torch firebird General Engine Discussion 28 10-29-2008 05:11 PM
