Project of the Month built by sbdtasos
Home Model Engine Machinist > Showing Them > A Work In Progress > Rupnow Ovehead Cam Air Cooled
Old 03-14-2017, 12:19 PM   #121
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 89 Times on 80 Posts
Default
Brian, Of course I enjoy it. I understand the need for a rest: Have at it!
I also hope to see a future build of something from you: They are all fun to follow and quite instructional. Rest now, but I think your brain might start itching with a new idea later.
Best of luck.
--ShopShoe
ShopShoe is offline
Old 03-17-2017, 05:09 PM   #122
Brian Rupnow
Liked 3627 Times on 2970 Posts
Likes Given: 36
Default
Today I'm at home for the first time in a week, as I've hit a temporary roadblock in the development of a spinforming lathe for a customer in Barrie. That's just fine, because I have a little project I want to take care of. The overhead cam engine works fine, but like all air cooled engines, it starts to suffer after about 15 minutes continuous running with no air movement to carry heat away from the cooling fins on the cylinder. I just happen to have a plastic fan 3 1/2" in diameter that I have rescued from something, but the pitch is wrong for my motor. However, the belt tensioner bearing revolves opposite to the crank and camshaft on that side of the engine, and is in a location where the fan would do the most good in terms of directing air flow over the cylinder. Todays exercise will be to find a way to attach the fan to the tensioner bearing so as to provide some cooling for the cylinder.
Brian Rupnow
Brian Rupnow is offline
Old 03-17-2017, 08:42 PM   #123
Brian Rupnow
Likes Given: 36
Default
So, here's the way it goes---I've had a 1 1/4" diameter length of round 316 stainless kicking around my shop ever since I built the Kerzel about a century ago. First step was to profile the end of it to fit into the recess in the back of the plastic fan. Second thing to do was try the fan on for fit before I tore down my set-up.
Brian Rupnow
Old 03-17-2017, 08:45 PM   #124
Brian Rupnow
Likes Given: 36
Default
Third thing to do was part off the required length (I love parting off under power feed but it scares me right to death.), flip the part around and counterbore the other side for the bearing--very light press fit. Fourth thing to do was use 638 Loctite on the bearing side and two part epoxy on the fan side, and put everything together.
Brian Rupnow
Old 03-17-2017, 08:53 PM   #125
Brian Rupnow
Likes Given: 36
Default
Now comes the tricky part---Taking the old belt tensioner bearing off and putting the new bearing/fan/adapter hub in place without letting the belt go slack and jump a tooth on either pulley. This would of course throw the valve timing out of whack, and I got so lucky with the very first time I set it up that I don't want to have to do it again.
Brian Rupnow
Old 03-18-2017, 12:39 AM   #126
Brian Rupnow
Likes Given: 36
Default
And here we have a rather nasty picture of the finished installation. Black never shows up very well in these digital photos using a flash. Tomorrow I will machine a cool little divot to plug the hole in the center of the fan and try to get a video up. everything works slick when turned by hand.
Brian Rupnow
Old 03-18-2017, 02:38 PM   #127
Brian Rupnow
Likes Given: 36
Default
I follow the machining forums a lot, and one of the things I take note of is the weird and wonderful set-ups that people use to cut unconventional shapes with their lathes. The brass "dress-up" part on the face of the fan required a set-up that I have never attempted before. As you can see in the picture, it's not just a disc of brass. Rather, it is a shallow cone, like the old Dodge Lancer wheel-discs. There is a 0.300" diameter "spigot" on one side which fits into the hole in the center of the fan. I turned it first, then parted off the 1.5" diameter brass to about 3/16" thick. I flipped the part around in the chuck, then with the lathe running in reverse I used my longest carbide tipped boring tool to reach out and machine the disc from the center outward towards the back of the lathe in successive passes using the top-slide manual advance handle until I had a nice shallow cone formed. I am very impressed how well that method worked. I have epoxied the .300 diameter "spigot" into the hole in the center of the fan, and I think it looks quite "dashing". I will let the epoxy set up for an hour, and then put up a video. I have test ran the engine with the fan in place before I committed myself by epoxying the brass cap in place, and the fan puts out a very respectable breeze.
Brian Rupnow
Old 03-18-2017, 03:49 PM   #128
Brian Rupnow
Likes Given: 36
Default
As promised, here is a video of the engine with cooling fan running.
Brian Rupnow
3
People Like This
Old 03-20-2017, 12:31 PM   #129
ShopShoe
Senior Member
ShopShoe's Avatar
Default
That brass cap really dresses up the fan. I like this one even more, now.
I've only ever made a shape like the brass cap myself by accident and by problems with my lathe. Now I gotta try it on purpose. Thanks for posting this refinement.
--ShopShoe
ShopShoe is offline
Water Cooled Webster bmac2 A Work In Progress 268 10-01-2015 12:44 PM
4 Cylinder Air Cooled Draw-Tech A Work In Progress 6 02-15-2013 01:15 PM
Red Wing Air cooled. Brian Thomas Finished Projects 12 04-13-2012 01:42 AM
Air Cooled H&M chads Engines From Castings 7 08-24-2011 02:41 PM
Air Cooled Red Wing Mike N Engines From Castings 13 02-05-2010 01:19 AM
