Project of the Month built by Johno1958
Home Model Engine Machinist > Building Them > General Engine Discussion > can leaf blower coil be used to run a Webster?
Old 06-25-2010, 05:50 PM   #1
Liked 2 Times on 2 Posts
Default can leaf blower coil be used to run a Webster?
Hey everybody,
I have pulled a coil out of an old leaf blower and am wondering if I can use it to provide spark for the Webster I'm working on. If the answer is yes then how would I go about wiring it? It has one small wire going in to the plastic part and the spark plug wire coming out. It appears to me that the laminated part that senses the magnet was grounded directly to the engine. Would it work to run a wire from the laminations to complete the low voltage part of the circuit? I'm obviously in over my head on this one so any help will be greatly appreciated.
pmerritt is offline
Old 06-25-2010, 06:16 PM   #2
Liked 17 Times on 17 Posts
Default Re: can leaf blower coil be used to run a Webster?
If the leaf blower had ignition points then the coil can be used.
If the leaf blower had no points, solid state ignition, then the coil won't work.
Grounding the laminations would complete your circuit.
ghart3 is offline
Old 06-25-2010, 08:14 PM   #3
Senior Member
Liked 33 Times on 30 Posts
on those magnetically induced coils there is no low voltage circuit.
the laminations are bolted to the engine and one end of the ht circuit is fixed to the lams as well.
the plug lead completes the ht circuit.
the small wire is connected inside the coil to the spark plug end of the ht circuit and is normally isolated but connects to the engine when the ignition is switched off so earthing the spark and stopping the engine.
hope this helps
I used to be confused, now I just don't know
wheeltapper is offline
Steam Blower 1hand Buy / Sell / Trade / eBay 0 01-17-2012 03:58 AM
Sliding Van Blower Drei General Engine Discussion 3 10-10-2011 09:38 PM
Ignition Coil DaveRC General Engine Discussion 6 01-29-2011 10:06 PM
2-56 Heli-coil? SAM in LA General Engine Discussion 8 05-22-2010 04:12 PM
Coil Krown Kustoms Plans 12 08-13-2009 01:40 AM
