Project of the Month built by gbritnell
Home Model Engine Machinist > The Tools and Tips > The Shop > Problem with the new lathe
Old 04-14-2017, 04:28 PM   #21
stragenmitsuko
stragenmitsuko's Avatar
Liked 47 Times on 28 Posts
Default
if it's a brushless dc motor it's supposed to feel like that .
You can rotate the shaft , say 15 , then feel a "bump" then rotate it again 15 etc .
Should be very consistent all the way .
My best guess , if it is a brushless dc , is a bad or faulty wired or poorly soldered hall sensor .
You can open the motor , but never ever take the rotor out . That would cause permanent and irrepairable loss of magnetism .
Pat
stragenmitsuko is offline
Old 07-02-2017, 02:10 AM   #22
Johno1958
Johno1958's Avatar
Liked 24 Times on 13 Posts
Likes Given: 239
Default
Finally it's up and running again . I sent a video off to them and they said
it is a motor fault so nearly 3 months went past and I received a new motor but the same problem persisted so I sent the motor back to them and they said it must be a control card issue . Another couple of weeks went past I received a new control card and yes she is a goer . I must admit I was getting quite irate at them for taking so long but I am very pleased at the outcome .
Now to start doing things .
Johno1958 is offline
bazmak Likes This
Mini Lathe switch problem orbsah Tools 5 01-28-2015 07:53 PM
Lathe Threading Problem Richard General Engine Discussion 18 04-23-2013 12:23 AM
Lathe Motor Problem vcutajar General Engine Discussion 4 12-30-2011 08:53 PM
Problem With New Lathe ozzie46 Tools 11 10-09-2009 07:02 PM
Lathe Problem....... Stilldrillin General Engine Discussion 8 11-26-2008 08:57 AM
