Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 09-13-2008, 04:01 AM   #41
Brass_Machine
Brass_Machine's Avatar
Liked 33 Times on 55 Posts
Likes Given: 3
Default Re: TB3 - Roll Call
The build numbers stay the same. I am just adding him as the 'show' engine we typically build. So everyone keep building the part numbers you were originally sent.
Thanks
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 09-14-2008, 01:38 PM   #42
Metal Mickey
Liked 19 Times on 18 Posts
Look chaps I don't want to be the centre of any problems. I only asked if it was too late to become involved. I never expected, nor want a finished engine. I enjoy the process rather than the end result. So I am happy to wait until a team build four is started.
I don't want to cause problems Brass_Machine so thanks for trying to add me to the list and I will look out for TB4.
Mike.
Have a look at my website ....... http://www.mikes-models.com
I use my lathe to turn 'a' round........then I go back....
Metal Mickey is offline
Old 09-14-2008, 01:53 PM   #43
chuck foster
Liked 38 Times on 38 Posts
hey mike i don't want you to think my post about how many parts to build was a complaint.
i would be very happy to build enough for ten more engines. as far as i'm concerned the more the merrier.
please.......join in on the fun
chuck
the northern chuck
chuck foster is offline
Old 09-14-2008, 02:27 PM   #44
Brass_Machine
Likes Given: 3
Mike.
Too late for that Mike. Just kidding.
Please stay in this build. It really isn't a problem to have you in it. There are no extra parts for anyone to build. They only thing that is changing is the distribution of the parts.
Eric
Old 09-14-2008, 02:43 PM   #45
Metal Mickey
Well if you are all sure.........................I didn't take any comments as complaints.........
Regarding numbers I didn't expect an engine. I really do like making, rather than running, so don't let the show one go. Keep it for shows, and not for me. It will only sit on a shelf.......
I will start on the cams next week if you are happy for me to do so. Before I start though, have you any idea of the material I should use?
Mike
Old 09-16-2008, 10:20 PM   #46
Brass_Machine
Likes Given: 3
Steel.
You sure you don't want an engine?
Old 09-17-2008, 04:00 PM   #47
Metal Mickey
I don't want to cause any trouble so if it means the show or charity one going to me then no I don't want one. If those two were protected and there was a true 'spare' then yes I would be happy to own one.
I have made the fixture but I can't start on the cams until I know what material to use. If anyone can help I would really appreciate it!. I am going to try making one as a practice in steel. I may even try hardening the practice one as I have the powder but have never used it.
Looking at the build instructions the flat on the cam will need to be done when it is with the engine as it is critical for timing. Since the author soldered some brass on the cam I guess it must be steel. Whether it needs anything more (including hardening) because of the type of engine, I will leave open for comment.
Really looking forward to producing them..........
Old 09-18-2008, 12:42 AM   #48
Dick L.
Liked 2 Times on 2 Posts
Hi Mike, I think Eric referred to the material in the post before your last one. (Steel)
As far as getting an engine , I feel every participant should get one.Speaking for myself here! If the spares are spoken for it's just another piece. We are doing this for the experience and enjoyment aren't we? Relax and have fun with it.
Dick
Dick L. is offline
Old 09-18-2008, 05:49 PM   #49
Metal Mickey
Ah! I thought he got the name wrong!
OK no need to harden I guess looking again at the type of engine. I get right on to it tomorrow. 15 cams in steel coming up
Tee hee...........................
Old 10-29-2008, 03:46 PM   #50
kustomkb
kustomkb's Avatar
Liked 61 Times on 58 Posts
I'm really sorry fellows, but I think I have too much on my plate right now to stay in this team build.
If it goes on long enough I may be able to free up some time down the road. I just have too many projects on the go at the moment.
-Kevin.
-Kevin.
"No charge for the extra weight reduction Eh!"
My Photo's My Video's
kustomkb is offline
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex General Engine Discussion 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
