Home Model Engine Machinist > Building Them > Team Builds > TB3 - Roll Call
Old 07-13-2008, 07:22 PM   #31
Brass_Machine
Brass_Machine's Avatar
Liked 33 Times on 55 Posts
Likes Given: 3
Default Re: TB3 - Roll Call
Steel is fine for the flywheels. No need for brass.
Eric
madmodder - Mod Central
We're all mad here. I'm mad. You're mad.
A still more glorious dawn awaits...-Carl Sagan
Brass_Machine is offline
Old 08-06-2008, 11:45 AM   #32
kvom
kvom's Avatar
Liked 614 Times on 485 Posts
Likes Given: 287
I ordered the brass for my parts, and I should have it next week.
I also showed the plan to my shop teacher, and he pointed out a minor "problem" with the push rod. The diameter of the rod (.125") is less than the major diameter of 6-32 threads (.138"). Therefore a 6-32 die will cut incomplete threads on the rod.
OTOH the major diameter for 5-40 threads is .125", so I'm wondering if all of the holes/threads for the pushrod/nut/follower should be 5-40.
Ideas from the group?
kvom is offline
Old 08-06-2008, 11:43 PM   #33
kvom
kvom's Avatar
Likes Given: 287
I may have found the answer to my own question. Seems most tap&die sets with 4-40 have 6-32 as the next larger size.
kvom is offline
Old 09-06-2008, 11:55 AM   #34
Metal Mickey
Liked 19 Times on 18 Posts
Is it too late to become involved? I would really like to be part of a team build sometime soon. Did I see that the cam is not allocated? I don't know how complicated it would be but am willing to learn..........
Have a look at my website ....... http://www.mikes-models.com
I use my lathe to turn 'a' round........then I go back....
Metal Mickey is offline
Old 09-06-2008, 02:36 PM   #35
Brass_Machine
Likes Given: 3
Mickey,
You want to take the cam? how about the arm too? If you want, we can add you. Let me know.
Eric
Old 09-06-2008, 02:49 PM   #36
Metal Mickey
GULP! I just hope I can live up to the task but I will certainly give it a go! Can you email me the plan for the part? I will make a final commitment when I see if I am up to it, but I am certainly willing!
Also can you private email me with the numbers and how it all works (the team build process)?
Mike
Old 09-11-2008, 07:19 PM   #37
Metal Mickey
Thanks for the plans, I will have a go at the cams if you like. Can I leave the arms for the moment, I want to be sure to complete what I start. If I get on well and no one else is doing them at that time perhaps we can revisit it then?
Mike
Old 09-12-2008, 01:49 PM   #38
kvom
kvom's Avatar
Likes Given: 287
By adding Mickey everyone needs to increase the number of their parts by 1. Luckily I made extras of mine!
kvom is offline
Old 09-12-2008, 11:43 PM   #39
Brass_Machine
Likes Given: 3
Nah, he can be the recipient of the 'show' engine.
Eric
Old 09-13-2008, 01:46 AM   #40
chuck foster
Liked 38 Times on 38 Posts
so just how many engines are we going to build
I'm hoping to have the cylinder heads (valves,guides,keepers etc ) finished in the next two weeks so let me know and if need be i will set up and make some more.
i have been making enough parts for 15 engines
chuck
the northern chuck
chuck foster is offline
Roll Pins? kvom Tips and Tricks 6 08-27-2010 04:19 AM
Moving a 310 lb. Shear/Brake/Roll RobasaurusRex General Engine Discussion 11 06-11-2009 01:19 PM
TB2 - Roll Call Brass_Machine Team Builds 0 06-20-2008 05:02 AM
TB1 - Roll call for Elmers OC Brass_Machine Team Builds 0 05-21-2008 06:31 AM
What Would You Call This? rake60 The Break Room 2 08-28-2007 01:12 AM
