Home Model Engine Machinist > Building Them > Team Builds > Australia and New Zealand team build anyone?
Old 09-02-2013, 10:54 PM   #151
hi speed scrap
Junior Member
Liked 17 Times on 10 Posts
Default
Hi all,
I have been working in NZ for the last few months, so have not
progressed at all, perhaps I could take up Aussie Jim's kind offer
of helping with the valve spring retainers.
Otherwise ready for seating valves and pre assembly, oh, and
thread sparkplug holes, just need to verify the thread used by
sparkplug maker.
hi speed scrap is offline
Old 09-03-2013, 10:51 PM   #152
AussieJimG
Liked 124 Times on 116 Posts
Likes Given: 4
Default
Help! It's all in French!!! That's if I am looking at the right drawings.
What sheet are the valve spring retainers on? And what are they called?
And I need to make 6 sets (or is that 7) right?
Jim
Engineering: Combining art & science to create artifacts from dreams (Henry Petroski)
AussieJimG is offline
Old 09-04-2013, 03:48 AM   #153
hi speed scrap
Junior Member
Default
Hi Jim,
I will send you a drawing in the next day or so, (In Engleeesh)!
7 sets I think from memory.
Old 09-04-2013, 08:44 PM   #154
AussieJimG
Likes Given: 4
Default
Thanks Dave, I think I have identified it but the hidden lines on the drawing worry me a bit in case there is something I am missing.
Are they brass or steel?
And please send a PM with the address to which I should send them.
I am looking forward to being useful.
Jim
Old 09-09-2013, 09:27 PM   #155
AussieJimG
Likes Given: 4
Default
Hi Dave,
I think I have made one collet. Think? It is so bloody small that I am not sure. I vacuumed the lathe first so I could find it when I parted it off and I think the bit I picked up is the collet but I won't know until I find a way to hold it to remove the flashes.
So far I have broken all of my 1mm drills but now I have made a sensitive drilling attachment (you wouldn't do it while you still had drills, would you?). Now I have some more drills and can have another go.
Please send the drawings when you can just in case I am making the wrong bit or the right bit the wrong size. And the address for sending them too.
Jim
Old 09-09-2013, 11:10 PM   #156
hi speed scrap
Junior Member
Default
Aaahh, so its not just me then Jim!
I have made a small change to make them a bit easier make.
I have a drawing nearly complete and some samples to
send to you.
Will send a PM later today.
Dave.
Old 09-10-2013, 05:24 AM   #157
hi speed scrap
Junior Member
Default
Jim, PM sent.
Old 09-10-2013, 08:38 PM   #158
AussieJimG
Likes Given: 4
Default
Dave, got the PM and have responded.
Do you think the collets would be ok if I just milled the slot? The only difference would be lack of radius at the bottom.
But I could then mill the slot for all the collets at once and then shape and part them in the lathe.
It's just a thought and I don't want to spoil the job just be being lazy.
Let me know (or maybe I should just wait for the drawings)
Jim
Old 09-17-2013, 09:42 AM   #159
AussieJimG
Likes Given: 4
Default
Thanks Dave, I got the drawing and the sample (beautifully made sample) and will start on them tomorrow or Thursday.
Jim
Old 09-17-2013, 01:31 PM   #160
hi speed scrap
Junior Member
Default
Jim,
Regarding your previous comment on the bottom of the slot, it is
my opinion that it needs to be radiused to match valve stem otherwise
there might not be enough load bearing surface to minimize wear.
I will leave that up to you!
The assembly I sent is the previous design, but valve and retainer
dimensions remain the same.
Dave.
Team Build No.5A JorgensenSteam Team Builds 4 03-08-2011 02:45 AM
I wish we'd team build a boiler now BobWarfield Team Builds 45 07-15-2008 01:40 PM
TB3 - IC engine team build Brass_Machine Team Builds 66 07-07-2008 01:16 AM
TB2 - Next Team Build Brass_Machine Team Builds 0 04-26-2008 04:48 PM
Team build Brass_Machine Team Builds 185 04-06-2008 06:32 PM
