Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Team Builds > Australia and New Zealand team build anyone?
Old 02-17-2013, 04:34 PM   #141
ausdier
Liked 83 Times on 59 Posts
Likes Given: 7
Default
To make the inlet and exhaust guides more interchangable it would simply mean having to make shim washer to go underneath.
With a pitch of 1.5mm and the fact that these don't need to line up in any perfect position.
You could get away with making some washers out of some copper shim of about 0.25mm.
Just an idea.
ausdier is offline
Old 02-22-2013, 03:39 AM   #142
gabby
Liked 15 Times on 9 Posts
Likes Given: 202
Default
Hi there Dave, the harbour is looking great as usual, I just wish I could afford to get out on it more often.
cheers
Graham
gabby is offline
Old 04-18-2013, 10:34 PM   #143
Kaleb
Senior Member
Kaleb's Avatar
Liked 22 Times on 16 Posts
Default
I'm starting to feel like I'm holding up everyone else on this build. Should I just send the flywheels out now? The fuel tank support columns take quite a few different setups to machine, so they take a while. Currently done 3, and nearly finished the 4th, but after I've done that one, I've still got 10 to go. Got several other projects going, as well as my HSC work for 3 of my subjects so please bear with me. After all, slow and steady wins the race. Rushing things gives poor results.
Steadily following the "Up Road"
Kaleb is offline
Old 04-18-2013, 10:58 PM   #144
Herbiev
Herbiev's Avatar
Liked 283 Times on 240 Posts
Likes Given: 91
Default
Hi Kaleb. I for one would be happy for you to send out what you have completed and continue as time permits. Your HSC quite rightly takes priority and as you say " rushing gives poor results".
Herbie
Hallett cove
South australia
Herbiev is offline
Old 06-04-2013, 09:58 PM   #145
Herbiev
Herbiev's Avatar
Likes Given: 91
Default
Just wondering if anyone else has completed their patrts?
Herbie
Hallett cove
South australia
Herbiev is offline
Stichnz Likes This
Old 06-04-2013, 10:24 PM   #146
hi speed scrap
Junior Member
Liked 17 Times on 10 Posts
Default
Hi Herbie
All machined up except for valve spring retainers, which
are very fiddly to say the least.
Hopefully get them done in a couple of weeks.
Getting there slowly!
Dave.
hi speed scrap is offline
Old 06-05-2013, 11:36 AM   #147
Herbiev
Herbiev's Avatar
Likes Given: 91
Default
No worries Dave. Just wondering what stage everyone was up to.
Herbie
Hallett cove
South australia
Herbiev is offline
Old 09-01-2013, 02:34 PM   #148
Cogsy
Cogsy's Avatar
Liked 486 Times on 378 Posts
Likes Given: 477
Default
Hey guys - whatever happened with this build? Did anyone end up with a running engine or have you all abandoned the idea?
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 09-02-2013, 11:43 AM   #149
Herbiev
Herbiev's Avatar
Likes Given: 91
Default
Still going Cogsy. All my bits are done. I'm sure the rest ain't far behind.
Herbie
Hallett cove
South australia
Herbiev is offline
Cogsy Likes This
Old 09-02-2013, 09:35 PM   #150
AussieJimG
Liked 124 Times on 116 Posts
Likes Given: 4
Default
If anyone needs a hand, just sing out. I still have some spare time.
Jim
Engineering: Combining art & science to create artifacts from dreams (Henry Petroski)
AussieJimG is offline
Team Build No.5A JorgensenSteam Team Builds 4 03-08-2011 02:45 AM
I wish we'd team build a boiler now BobWarfield Team Builds 45 07-15-2008 01:40 PM
TB3 - IC engine team build Brass_Machine Team Builds 66 07-07-2008 01:16 AM
TB2 - Next Team Build Brass_Machine Team Builds 0 04-26-2008 04:48 PM
Team build Brass_Machine Team Builds 185 04-06-2008 06:32 PM
