Project of the Month built by driller1432
Home Model Engine Machinist > Building Them > Team Builds > Australia and New Zealand team build anyone?
Old 12-28-2012, 10:14 AM   #131
Kaleb
Senior Member
Kaleb's Avatar
Liked 22 Times on 16 Posts
Default
Got 4 of the flywheels done in mild steel. I'll be shipping out once all of my parts are done. Looks like I'll be doing the pistons and cylinders unless someone else wants to make them.
Steadily following the "Up Road"
Kaleb is offline
Old 01-07-2013, 08:14 AM   #132
Kaleb
Senior Member
Kaleb's Avatar
Default
How's everyone getting on? I haven't seen any updates for a while.
Kaleb is offline
Old 01-07-2013, 09:28 AM   #133
wm460
wm460's Avatar
Liked 14 Times on 12 Posts
Default
I would be interested in the next team build, I should have a mill then.
Mark
wm460 is offline
Old 01-07-2013, 10:26 AM   #134
Herbiev
Herbiev's Avatar
Liked 283 Times on 240 Posts
Likes Given: 91
Default
Hi Kaleb. All my bits are done and ready to go.
Herbie
Hallett cove
South australia
Herbiev is offline
Old 02-05-2013, 02:52 AM   #135
Kaleb
Senior Member
Kaleb's Avatar
Default
The flywheels are done. I've made a start on the fuel tank support columns, but will need a boring bar for the cylinders.
Kaleb is offline
Old 02-05-2013, 12:31 PM   #136
hi speed scrap
Junior Member
Liked 17 Times on 10 Posts
Default
well done Kaleb,
I will post some pics on the heads this weekend.
Dave.
hi speed scrap is offline
Old 02-16-2013, 01:47 AM   #137
hi speed scrap
Junior Member
Default
Hi guys,
I have been inundated with work since xmas so progress is a bit slow, however all
heads are machined up, just need threading.
Valves, 10 done
Guides, 4 done.
Having fitted the guides to the head (as pic), it is hit and miss that they line up
squarely with the head, of 4 giudes fitted, only one lines up nicely with the
head allowing drilling of the exhaust/inlet ports.
I have machined one giude to get correct fit, very time consuming, this thern makes
each head assy a matched set, so parts will not be interchangeable.
Perhaps shims under the guides might work?
Also had to machine the hex back from the end by 0.5mm to stop the corners of
hex from marking the head on assembly.
hopefully get some machining done today, unless shed is an oven!
Old 02-16-2013, 07:37 AM   #138
metalmad
metalmad's Avatar
Liked 292 Times on 213 Posts
Likes Given: 26
Default
Hi Guys
Im really looking forward to seeing this go together
pete
A little bit every day, sometimes the same little bit!
Skype - metalmad11
metalmad is offline
Old 02-16-2013, 07:55 PM   #139
gabby
Liked 15 Times on 9 Posts
Likes Given: 202
Default
Ok curiosity has got me Whats the piston out of ? it looks quite techo.
Graham
gabby is offline
Old 02-16-2013, 11:27 PM   #140
hi speed scrap
Junior Member
Default
Hi Gabby,
Piston is from Cummins Signature engine, approx 137mm dia.
They are hollow crown, (can faintly see oil hole on left side) for
better cooling. This one done 1.4 m k's at 600hp.
It is a bit techo looking I spose. Cat use the same piston too.
Hows the harbour today? full of boats I spose. I spent 20 yrs
cruising the Hauraki and further in our boat, great place!
Dave.
Team Build No.5A JorgensenSteam Team Builds 4 03-08-2011 02:45 AM
I wish we'd team build a boiler now BobWarfield Team Builds 45 07-15-2008 01:40 PM
TB3 - IC engine team build Brass_Machine Team Builds 66 07-07-2008 01:16 AM
TB2 - Next Team Build Brass_Machine Team Builds 0 04-26-2008 04:48 PM
Team build Brass_Machine Team Builds 185 04-06-2008 06:32 PM
