Project of the Month built by gbritnell
Home Model Engine Machinist > The Tools and Tips > Tools > Question of cleaning
Old 12-09-2017, 05:45 PM   #31
JCSteam
Liked 37 Times on 34 Posts
Likes Given: 199
Default
DJP, agreed, comments on blockages are very real, and I think I've already identified where the blockages are going to be, so the small end of the nossle will be first to go, the hose is accessible from both sides with the assistant of a long broom handle. The other area that's likely to cause a blockage is where the hose goes into the cylinder, as the hole is only half the size of the hose, (assuming to create the cyclone effect). Like I said if it's no good it'll go in the bin.
JCSteam is offline
Old Yesterday, 04:08 AM   #32
deeferdog
Liked 196 Times on 77 Posts
Likes Given: 39
Default
I have found that the best unblocking tool is what electricians use as a "snake" for pulling wires through conduit. This is a plastic strip available from hardware stores. The strip is actually used to join sheets of chipboard flooring and only cost a couple of bucks. Cheers, Peter
deeferdog is offline
JCSteam Likes This
file cleaning canadianhorsepower General Engine Discussion 30 06-16-2013 09:23 PM
Cleaning A New Lathe wm460 General Engine Discussion 10 01-16-2010 08:48 AM
cleaning ally firebird General Engine Discussion 8 12-12-2009 12:00 AM
Cleaning a New Lathemaster 9 x 30 Kermit Machine Modifications 12 12-22-2008 03:03 AM
Cleaning bores GailInNM Tips and Tricks 0 07-28-2008 03:32 PM
