Project of the Month built by edholly
Home Model Engine Machinist > Foundry - Home Metal Casting > Home Foundry & Casting Projects > First sand casting
Old 03-10-2017, 07:16 PM   #1
stragenmitsuko
stragenmitsuko's Avatar
Liked 42 Times on 24 Posts
Default First sand casting
Today I poured my very first sandcasting .
Been casting alum for a couple of years now , mostly I simply fill all kinds of tin cans to cast rounds and squares wich can then be used on the lathe and mill .
So I decided to take it one step further , make a pattern and give it a go .
Turned out quite acceptable for a first try .
The part is half a carriage for a moving gantry cnc router I'm building .
The other half was also cast , but I don't have pictures .
Furnace , greensand , flasks and offcourse the pattern ..... it's all homemade .
Greensand was made from construction white sand , powdered bentonite and water . The bentonite was like flower , very fine and dry . I found it at a garden center .
The surplus of molten metal was poured in a couple of tincans .
I use a lot of these round "stock" for all kinds of things .
Pat
stragenmitsuko is offline
3
People Like This
Old 03-10-2017, 08:13 PM   #2
stragenmitsuko
Default
Couple of more pictures of what it should look like when finished .
The two bores will get 4 lineair bearings wich will slide on two supported rails on a fully supported frame . More a design exercise then a practical machine .
These two "prototypes" were carved out out of a large block I cast in a square paintcan .
Took a lot of metal to remove , the entire shop was full of chips .
And when I finally got there , I goofed up with the two bores .
On both parts .
So start over again from scratch , hence the sand casting to avoid removing all that metal again .
Now let's see if I can getthose bores right this time .
The steppers are rotating nut types .
A fixed leadscrew has several advantages , and the steppers already have an integrated inti backlash nut .
Well worth giving it a try
4
People Like This
Old 03-10-2017, 10:09 PM   #3
Herbiev
Herbiev's Avatar
Liked 252 Times on 213 Posts
Likes Given: 79
Default
Nice work. Especially for a first casting.
Herbie
Hallett cove
South australia
Herbiev is offline
Old 04-22-2017, 08:54 AM   #4
xlchainsaw
Liked 15 Times on 15 Posts
Default
i was thinking the same
xlchainsaw is offline
Old 04-22-2017, 01:36 PM   #5
vederstein
Project of the Month Loser!
vederstein's Avatar
Liked 258 Times on 166 Posts
Likes Given: 72
Default
I'm envious. I hope set up an aluminum foundry some day, perhaps this year or next.
vederstein is offline
Old 04-22-2017, 05:13 PM   #6
stragenmitsuko
Default
Thx for all the nice comments guys , I'll post some pictures of the furnace I made from a propane tank .
I don't have anyone round here to teach me or to guide me .
So all I've learned sofar comes from the interenet .
There's a guy called myfordboy on youtube showing 50+ video's on patternmaking , moulding , casting .... Very informative , I highly recomend looking at his channel if you want to learn how to do this .
Mrpete222 also has some real nice step by step video's on the subject
And offcourse there are several others .
2
People Like This
lost wax casting in sand ? kadora General Engine Discussion 16 08-25-2015 07:11 AM
printing a sand casting dnalot Home Foundry & Casting Projects 4 07-08-2013 06:38 AM
Casting Sand Recipe ShedBoy Home Foundry & Casting Projects 16 02-01-2013 02:20 PM
Sand molds for casting 100model Home Foundry & Casting Projects 2 01-15-2013 11:33 PM
Casting Sand for sale Rocket Man Buy / Sell / Trade / eBay 0 06-16-2012 06:54 PM
