Home Model Engine Machinist > Showing Them > A Work In Progress > Building of TINY INLINE 4 in Brazil
Old 04-19-2018, 08:03 PM   #191
e.picler
Edi from brazil
Liked 125 Times on 58 Posts
Likes Given: 3
Default
Hi to all!
The new camshaft blank is ready for the lobes.
Click image for larger version
I'm really confused about how to use the lobes table bellow. For exemple cylider #1 Exaust closed 0 degrees Exaust open 130 it does not form the 50 angle within lobe flanks
Can anyone help me with that?
I don't remember how I figure that out for the old camshaft because I did a program on Mastercam to generate the G code and I don't want to use it again.
Thanks,
Edi
e.picler is offline
2
People Like This
Old 04-20-2018, 03:32 PM   #192
e.picler
Edi from brazil
Likes Given: 3
Default
An update on the camshaft issue.
Reading the instructions with very close attention, I found what I was doing wrong.
It had to do with how to start the cutting of the first lobe. I was doing it backwards.
After having the understanding on how to start the machining, strictly following the table, I have cut the lobes.
The photo bellow shows the correct and the wrong camshaft. The one on the botton (black end) is the correct one. Please observe that the lobes are inverted
Still missing to grind the ends of the bushings bearing. I will do that tomorrow
Edi
e.picler is offline
2
People Like This
Old 04-21-2018, 02:22 AM   #193
johnmcc69
Liked 19 Times on 18 Posts
Likes Given: 22
Default
Looking good Edi! Not too long before the first "pop".
johnmcc69 is offline
Old 04-21-2018, 03:17 AM   #194
e.picler
Edi from brazil
Likes Given: 3
Default
Hi John!
Yes, almost there!
I have finished the camshaft today ant tested it on the engine. It seems to be OK.
Tomorrow I will install the distributor and try to staTI4 again but, first I will machine a starting tool. I have purchased a OneWay bearing 5X9X9 which will be installed in a small shaft with a pocket in one end for the bearing and use a battery drill bit machine.
I have tried to use a Dremel machine with a pulley as per the project however, it did not work not enough power.
Tks,
Edi
e.picler is offline
Tiny Inline 4 Cylinder IC kcmillin A Work In Progress 340 06-21-2015 09:14 PM
Tiny Inline 4 Cylinder IC Plans For Sale kcmillin Plans 20 08-17-2014 05:41 PM
CS building the Tiny 4 cyl. inline. crankshafter A Work In Progress 22 07-15-2012 07:01 PM
Inline 6 aircraft engine or inline 4 model aircraft engine plans required Alex3886 Plans 20 05-24-2011 04:42 PM
Tiny Inline 4 Cylinder IC kcmillin Finished Projects 15 05-24-2011 03:40 AM
