Home Model Engine Machinist > Building Them > Engines From Castings > Rudy Kouhoupt's Open Column Steam Engine - Cast & Double Size
Old 03-18-2018, 10:47 PM   #91
Herbiev
Herbiev's Avatar
Liked 291 Times on 247 Posts
Likes Given: 97
Default
Coming along nicely
Herbie
Hallett cove
South australia
Herbiev is offline
Old 03-19-2018, 10:49 AM   #92
deverett
deverett
Liked 184 Times on 140 Posts
Default
I admire your tenacity.
The Emerald Isle
deverett is offline
Old 03-25-2018, 08:41 PM   #93
vederstein
Must do dumb things....
vederstein's Avatar
Liked 306 Times on 196 Posts
Likes Given: 90
Default
Today was dedicated to machining the flywheel. This is really the first time I've machined zinc. It was quite enjoyable. The chips were small and not stringy. I've added a short video of an OD pass to show. It cut easily and it shiny. Good stuff.
No need for a bunch of descriptions here. The photographs should be self-explanatory.
...Ved.
vederstein is offline
Buchanan Likes This
Old 04-08-2018, 07:13 PM   #94
vederstein
vederstein's Avatar
Likes Given: 90
Default
It took four tries at making the valve, but I finally got the engine to somewhat run.
Being single acting engine with the rotating face valve that Rudy K. designed, this engine will never make real power.
But hell.. IT RUNS!!!!!!!!!!!!!!
I hope that as it breaks in it will improve. Though the biggest issue is for such a large diameter piston, the porting is small. Therefore the 180-190 degrees of non-powered movement is restricted by the exhaust valve ports making the engine far less efficient. The small porting also contributes to the jerky motion.
Old 04-08-2018, 07:18 PM   #95
vederstein
vederstein's Avatar
Likes Given: 90
Default
After my successful test run it's time to disassemble the engine for painting.
My wife wasn't too keen on painting it because she wanted the raw cast surface to show people that I was one who make the castings.
But alas, this is my hobby. Not hers. So we have paint. This time I went for blue.
Instead of a rattle can, I went with a brush this time. With a brush I hope I can control the edges a bit better and fill in the rough casting surface a bit.
That's it for this week.
...Ved.
rweber Likes This
Rudy Kouhoupt Engine GKNIPP Plans 13 08-05-2016 02:14 PM
Rudy Kouhoupt Copperhead Steam Roller olympic Plans 4 01-04-2014 08:24 PM
Rudy Kouhoupt Striling engine Gordon General Engine Discussion 25 03-25-2012 07:27 AM
Pioneer Engine by Rudy Kouhoupt tup48 Buy / Sell / Trade / eBay 1 10-30-2009 12:44 AM
Rudy Kouhoupt's Steam tractor Ben_Imbrock General Engine Discussion 2 10-28-2009 01:31 AM
