Home Model Engine Machinist > The Tools and Tips > Tips and Tricks > Polishing aluminum to a mirror finish?
Old 07-04-2017, 09:57 AM   #11
rodw
Liked 313 Times on 244 Posts
Likes Given: 161
Default
I'm with Cogsy and finish with autosol after working through wet and dry grades to about 1200 and some kerosene. Doing this on a lathe is quick and one piece used almost daily for about 3 years still looks nice and shiny
RodW
Brisbane, Australia
vehiclemods.net.au
rodw is offline
Old 07-04-2017, 11:36 AM   #12
Billitmotors
Liked 15 Times on 11 Posts
Default
If you are polishing a part spinning it in the lathe, like an aluminium cylinder head with or without fins, try using a fine Steelo soap pad used wet. Try getting the best possible machined finish you can without using abrasive paper before you start polishing. If you want an even better finish after using the soap pads, get some very soft flanalettte material, or even better soft cotton like old underpants material and use some Pennybrite polish which appears to be finer abrasive paste than Autosol.
ALWAYS remember to keep the size of the polishing pad as small as possible, so that it can't get wrapped around the job and pull your hand into the chuck.
Also it is best to cover the bed of the lathe with plastic to stop the water and even more so the abrasive paste getting on the bed.
Rob.
Billitmotors is offline
Old 07-04-2017, 12:17 PM   #13
nautilus29
Liked 11 Times on 8 Posts
Default
Thanks for all of the suggestions! I'll try some of these aluminum polishes and see how it turns out. I've been staying away from using buffing wheels because I don't want to round the edges of my part.
nautilus29 is offline
Old 07-17-2017, 09:30 AM   #14
Nick Hulme
Liked 67 Times on 50 Posts
Likes Given: 32
Default
Polishing is an art, part of which is choosing the size, material and direction of buffing wheel to avoid unwanted changes in shape, in general you will want to have the buffing action across a surface and only just reach, or drop off the edge, having the buffing material run up an edge then across a surface will round the edge significantly. There is a similar consideration when buffing paintwork where buffing over an edge onto a surface will usually strip off the paint ;-)
- Nick
W.C. Fields said "You can't cheat an honest man", he should have followed that with "But, you can always find a credulous fool if you need one"
Nick Hulme is offline
Old 07-17-2017, 01:04 PM   #15
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
Default
Originally Posted by Naiveambition View Post
Here's my experience
I've done a fair share of different alum. The best finish will always be billet style alum. And degrades when cast, magnesium etc... So metal type is important in achieving a true mirror finish.
N,
You will notice that the picture I showed above is a cast material, and is well known for not being much good. These were from my own era, and know first hand how bad they were, you only had to tap the castings and spider web cracks appeared, in fact, on the larger piece, I had to grind out and repair such a fault before reshaping and polishing.
This shows the part having a rev counter boss being fitted. It is a shame that the spiders web can't be seen correctly, it is just to the left of the bright hi-light.
Dressing back to get the shaping correct.
I gave up on hand finishing with Autosol or any other tube or liquid based aluminium polishes because they just couldn't get the depth of shine that I wanted.
When the new plastic polishing wheels and soaps came along, it answered all my prayers, I could then get a hard chrome like finish on ANY non ferrous materials, including brasses and all it's ranges and all plastics. A thing that just can't be achieved by hand polishing.
People say that you get rounded over edges with buffing wheel polishers, but that only happens when you don't know what you are doing. In fact, I can sharpen up edges with the correct wheels and compounds.
Marvelous what you can do when it is done correctly.
BTW, I was shown all the tricks when watching the stainless polishers in R-R for a couple of years, doing their thing, they could work wonders with a scruffy old bit of welded up SS, which most of it started life as.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 07-22-2017, 10:08 AM   #16
nautilus29
Default
Looks like I need some practice using buffing wheels, and or a softer wheel. While doing some test runs with a buffing wheel I was having some issues with inconsistent finish. I noticed some of the info online suggests a softer wheel when you are close to being done, and I wonder if the hard felt wheels I'm using is hurting my feel.
After seeing some of the finishes you guys are getting I know it can be done! Thanks again for all of the tips!
Old 07-22-2017, 10:28 AM   #17
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Likes Given: 77
Default
N,
I only use hard felt wheel when I have to remove large bits of machining marks or for digging out and flatting off large dings. I also use them to cut back radiused edges to get them square again, they really are like a soft grinding wheel, but only used to reshape metals, not to polish them.
After that, stitched wheels will start to get your shine. Once that is carried out and you have a sort of deep lustre the string cotton (plastic polishing wheel) comes into action to give you that chrome like finish that we all want.
If you are after a brushed effect to the finish, then invest in a brass wheel. This can also be used very effectively when cleaning up silver soldered parts. When it starts to become ineffective (brass wires bent back) then just turn it around on the pigtail and it will be just like new.
http://www.proopsbrothers.com/6x22-1...231-1130-p.asp.
There is a lot more to it than this, but these are the basics.
Old 07-23-2017, 06:46 AM   #18
bazmak
BAZMAK
bazmak's Avatar
Liked 1094 Times on 622 Posts
Likes Given: 854
Default
I remember doing the cast iron fireplace with fine polish and cloth
we called it burnishing
bazmak is offline
Old 07-29-2017, 08:39 AM   #19
Nick Hulme
Likes Given: 32
Default
Finishing wheels are a stack of cotton sheets sewn together.
Part of the advantage of these finishing wheels is that it's almost impossible to apply too much pressure, they are also the only wheel style which will work properly with a fine finishing polish, coarser wheels will leave artefacts and often lead to the conclusion that polishes like Autosol don't give a true mirror finish, they do if used correctly ;-)
- Nick
Old 07-29-2017, 09:18 AM   #20
goldstar31
Liked 382 Times on 329 Posts
Likes Given: 603
Default
Ah Yes- the three B's or Bullsh1t Baffles Brains. The RAF Museum at Cosford has a DH Devon C1 which was originally made as a Dove and registered VP-952. She came to RAF Hendon in 1949 to replace the aging Avro Anson 19's of RAF 31 Squadron( The Goldstars)
She was polished by the pilot and he polished through the cladding and had to be rebuilt.
'981 was the boss of Coastal Command's private kite and it became the hack for the Battle of Britain Memorial Flight after its Hendon days.
They were ALL looked after by LAC John Leggett who also looked after Jimmy Robbs Spitfire SL-721-- JM-R which is still flying.
We're still mates though John is a bit shaky now
Happy Days
Norm
goldstar31 is offline
Polishing flat aluminum Fingers General Engine Discussion 8 01-07-2011 04:53 AM
Aluminum finish techniques? QSPSB General Engine Discussion 19 12-21-2010 07:24 PM
Polishing dnp101677 General Engine Discussion 3 05-04-2010 08:29 PM
Mirror finish shred Tools 7 11-15-2009 04:06 PM
Where to buy metric sized aluminum rod - smooth finish? David Morrow Metals 7 03-13-2009 10:30 PM
