Home Model Engine Machinist > The Tools and Tips > Metals > Minnie Traction Engine
Old 07-17-2017, 04:22 AM   #1
madmachinist
Default Minnie Traction Engine
I am building a 1 1/2 inch scale Minnie Traction Engine. My question is, what would be the best materials to use for the cylinder liner and piston? My thoughts were cold-rolled steel for the liner and aluminum for the piston. I could use 660 bronze and stainless for the piston. What are your thoughts on this? Alan.
madmachinist is offline
Old 07-18-2017, 12:10 AM   #2
Brian Rupnow
Liked 4125 Times on 3271 Posts
Likes Given: 37
Default
For a low revving engine, cast iron is your best bet, because of it's self lubricating properties.
Brian Rupnow
Brian Rupnow is offline
Old 07-20-2017, 07:16 PM   #3
madmachinist
Default
Thanks for the imfo . I am trying to track down some mehanite or decent cast iron . not so easy to get a short end.
Old 07-20-2017, 08:19 PM   #4
Brian Rupnow
Likes Given: 37
Default
My supplier in Barrie Ontario stocks grey cast iron in 2" and 2 1/2" diameters, and sells it by the linear foot. I don't know where you are, so it is difficult to advise you.
Brian Rupnow
Old 07-21-2017, 12:45 AM   #5
petertha
Liked 222 Times on 169 Posts
Likes Given: 4
Default
Who is your supplier Brian?
petertha is offline
Old 07-21-2017, 12:56 PM   #6
Brian Rupnow
Likes Given: 37
Default
Barrie Welding on Anne street 705-726-1444
Brian Rupnow
Old 07-21-2017, 11:17 PM   #7
abby
Liked 83 Times on 62 Posts
Likes Given: 8
Default
Gun metal or brass is quite satisfactory for both the cylinder and the piston , steel is not recommended ...........it will rust when the engine is not in use .
abby is offline
Old 07-23-2017, 02:11 AM   #8
madmachinist
Default
have tracked down some 660 and also some cast iron . big decision ?
Old 01-11-2018, 09:30 PM   #9
justisla
Liked 1 Times on 1 Posts
Default
deleted old post
justisla is offline
1.75" Minnie Traction Engine dnalot Finished Projects 8 04-02-2016 12:24 AM
1.75” Minnie traction Engine dnalot A Work In Progress 56 03-31-2016 12:36 AM
Minnie 1" Scale Traction Engine - 1 year into build! Inky Engines A Work In Progress 9 09-24-2015 12:04 PM
"Minnie" traction engine Lindo Plans 6 09-09-2014 03:43 PM
Traction Engine lugnut Photos and Videos 1 09-08-2007 05:24 PM
