Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Arduino Rotary Table for Dummies
Old 07-16-2017, 06:21 PM   #61
billanygard
Liked 1 Times on 1 Posts
Default
I did as been told, swap tm with 1200.
BUT!
Still 1040 steps for 360 degrees
Olsson
billanygard is offline
Old 07-16-2017, 09:59 PM   #62
Foozer
Foozer's Avatar
Liked 82 Times on 70 Posts
Default
BUT!
if your steps are 200 per rev with table ratio of 3:1, 3 revolutions of the stepper is 1 turn [360] of the table or 600 steps. So thinking you wanted to step 1200 steps is 2 turns [720] of the table . Half stepping [400] will give you 1200 at 3:1 for 1 turn.
So whats off? steps per revolution or the table ratio?
const int StepsPerRotation = ?; // Set Steps per rotation of stepper
const int TableRatio = ?; // ratio of rotary table
"Nothing is more irritating than that which exposes the pedigree of ideas"----Lord Acton----
Foozer is offline
Old 07-16-2017, 11:01 PM   #63
bmac2
bmac2's Avatar
Liked 555 Times on 400 Posts
Likes Given: 230
Default
Hi Olsson. I think Fooser has it. Check the settings on your stepper driver and remember to work that in for the “StepsPerRotation”
Alberta, Canada
bmac2 is offline
Old 07-16-2017, 11:11 PM   #64
bmac2
bmac2's Avatar
Likes Given: 230
Default
Hello all of you!
Sometimes when you see something it says clonk in the head "That should i build".
This was such a thing.
Ordered missed components, draw a nice box and 3d printed it, hooked it up and its working.
BUT!
I use it for my 4th axels thing to my cnc router. 200steps/rot, beltgear 1:3 and it is impossible to get the controller to give the right steps. I need 1200 and get 1040. Fiddeling with numbers in the script only change between 1040 and 1440steps.
Any tips?
I know a few people around here have been asking about 3D printing a box for this project. I know Chuck (chucketn) would like to print one. Any chance you could post your STL file?
Alberta, Canada
bmac2 is offline
Old 07-16-2017, 11:26 PM   #65
bmac2
bmac2's Avatar
Likes Given: 230
Default
Originally Posted by dnalot View Post
Hi Chucketn
Here is a link to amazon. com for the box. Note it took a few weeks to get
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
And here is the link for the power inlet
And the power supply
Mark T
This is a little off topic but hey it’s my thread.
Mark I think I saw your avatar (http://www.homemodelenginemachinist....ad.php?t=22722) or its cousin in the wild while we were on vacation in BC a couple of weeks ago. My wife takes pictures of the pretty things . . . I’m always looking for the rust!
Alberta, Canada
bmac2 is offline
Old 07-17-2017, 12:40 AM   #66
Foozer
Foozer's Avatar
Default
const int Multiplier = (StepsPerRotation * TableRatio)/360;
Only returns a whole number,
'member trying this script , my numbers were (400 *36)/360
for 40 steps per degree
400 steps per rev @ 36 || 27 || 18 || 9 returns whole steps
i.e. 400 36 14400 40 400 35 14000 38.8888888889 400 34 13600 37.7777777778 400 33 13200 36.6666666667 400 32 12800 35.5555555556 400 31 12400 34.4444444444 400 30 12000 33.3333333333 400 29 11600 32.2222222222 400 28 11200 31.1111111111 400 27 10800 30
The Bride loved the picture . . she wants one . .
Foozer is offline
Old 07-17-2017, 03:00 AM   #67
dnalot
Project of the Month Winner !!!
dnalot's Avatar
Liked 417 Times on 130 Posts
Likes Given: 69
Default
Hi
Nice, thanks for sharing
Mark
dnalot is offline
Old 07-18-2017, 07:51 AM   #68
billanygard
Default
Hello again!
I was not clear enough in describing.
Steps/rev for motor = 200 set for halfsteps give 400steps/rev and with 1:3 gear need 1200 / rev.
I can see about those even numbers but dont understand yet how it rounds off in the end.
For now when ask for 360deg i get some 324 and hoping to get closer.
STL
Nema problema, would be happy if someone find them useful.
There are about 2x5hr printing time, print without cooling and with raft and support.
Let stay long on the buildplate for cooling, long things wrap easily.
I use som round 5mm alu pillars for the circuit mount and also for the two caseparts.
Olsson
chucketn Likes This
Old 07-18-2017, 12:46 PM   #69
chucketn
Senior Citizen
chucketn's Avatar
Liked 137 Times on 120 Posts
Likes Given: 96
Default
Thank you for sharing your enclosure, billanygard.
Chuck in E. TN
HF X2, Micromark 7x14, Green 4x6 bandsaw, Anet A8 3d printer
chucketn is offline
Old 07-28-2017, 04:29 PM   #70
billanygard
Default
I know what I have done, but do not know what I did!
I was not satisfied about the resulution I get with my 1:3 ratio so I set down and read the script up and down up and down
as I understand what i was reading.
The worst thing that could happen if i changed something would be that is not function so I changed some rows.
032 const int Multiplier = (StepsPerRotation * TableRatio)/360; // 200*90=18000/360 = 50
to
032 float Multiplier = (StepsPerRotation * TableRatio)/3.6; // 200*90=18000/360 = 50
102 ToMove = (Degrees*Multiplier);
to
102 ToMove = (Degrees*(Multiplier/100));
109 ToMove = (Degrees*Multiplier);
to
109 ToMove = (Degrees*(Multiplier/100));
This was an huge change with just a few steps at worst eg 36x10°=1198 instead of correct 1200.
I have read a little in an "sidethread" about another solution but for now that is to heavy for me.
//Olsson
Olsson
wtb rotary table toolroom Buy / Sell / Trade / eBay 7 03-06-2018 12:58 PM
Arduino control for a 3” rotary table bmac2 Machine Modifications 101 04-23-2017 01:17 AM
Rotary table Coomba General Engine Discussion 64 08-22-2016 04:34 PM
My Second Rotary Table,80 mm table. gus Introduction 75 07-29-2014 08:36 PM
Using a rotary table. radfordc General Engine Discussion 10 03-10-2009 12:58 PM
