Home Model Engine Machinist > Showing Them > Finished Projects > A Tiny 3 cylinder Holt based engine
Old 10-19-2017, 08:41 PM   #1
gbritnell
gbritnell's Avatar
Liked 552 Times on 527 Posts
Default A Tiny 3 cylinder Holt based engine
Gentlemen,
Well the engine is finished and running. If you followed the build thread then you know the construction and initial running wasn't without incidents.
Today I took it out on the bench and after a few adjustments it ran quite well but much faster than I had expected. The simple carb was much similar to the one used on the series of Tiny hit and miss engines so with the increased bore diameter of this engine I thought it would run slower.
I took it back down to the shop and installed the original throttling carb then went back out for another try.
While turning it over I started opening the needle valve until it caught and ran. While running I adjusted the ignition timing from the initial setting of about 15 degrees to almost 25 and it smoothed right out.
Here is the video published on Youtube.
Thanks for following the build and commenting along the way.
gbritnell
P.S. I'll have it at the Zanesville engine show this weekend.
https://youtu.be/c_KtDdeMepk
Talent unshared is talent wasted.
gbritnell is offline
13
People Like This
Old 10-20-2017, 12:18 PM   #2
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 122 Times on 111 Posts
Default
Outstanding.
I followed the build, but I didn't really understand how small it is until now. It's such a nice runner and it still kinda sounds like a Holt.
I envy your speed in completing projects. Best of luck with what's next.
--ShopShoe
ShopShoe is offline
Old 01-11-2018, 05:40 PM   #3
Tad Wicks
Liked 3 Times on 3 Posts
Default
You continue to ''WOW'' us, great job, that is a real cutie. Tad
Tad Wicks is offline
Tiny Inline Four 4 cylinder engine for sale itbookham Buy / Sell / Trade / eBay 1 02-13-2017 08:44 PM
Tiny Inline 4 Cylinder IC kcmillin A Work In Progress 340 06-21-2015 09:14 PM
Tiny Inline 4 Cylinder IC kcmillin Finished Projects 15 05-24-2011 03:40 AM
Cole 4 cylinder holt from castings enginebob Engines From Castings 5 09-22-2009 01:49 AM
