Home Model Engine Machinist > Showing Them > Photos and Videos > My first build.
Old 01-05-2018, 01:18 PM   #1
PhilPassmore
Liked 11 Times on 1 Posts
Default My first build.
Have had a lathe for ages, and recently aquired a small mill, so decided it was time for my first ever steam build, sort of nudged along by a certain liking of the 'steam punk' genre that is happening these days. Based very much on the Steve's Workshop simple oscillating engine design, but with other bits added along the way, mostly as proof of concept should I decide to do something more adventurous. All the parts other than pipe unions (because I really couldn't be bothered), and the pressure gauge (because I couldn't) are scratch built. The burner was canibalised from a cheap gas camping stove from the orient together with a scratch built tank, fitted with a fill valve from a pencil blow torch. The boiler support ends are cut from 6mm aluminium sheet, and the stainless sides were 'Q' punched and rebated for the air holes, riveted and screwed to the various bits. Oil cups and a displacement oiler are fitted, though need to work on the displacement oiler to limit the flow of oil. The manual fill pump again is scratch built, together with the clack valves, but I haven't yet fitted a sight glass, so keeping the boiler topped up is a bit hit and miss. The feed water tank is fitted with a heat exchanger coil fed from the exhaust, so the feed water is pre-heated before getting pumped into the boiler. The coil is actually VERY efficient, bringing the feed water up to almost boiling, before the exhaust finally drops into a collection tank. The boiler cladding is an idea pinched from elsewhere, consisting of wooden coffee stirers, glued to a thin piece of veneer. It's done in two halves so can be removed relatively easily. This is then stained and sealed. I have run the wet header from the boiler, back under the boiler to provide a rudimentary steam drier, and to be honest, I have no idea if it helps at all. Being a steam engine, it wouldn't be complete without a whistle, though mine leaves a bit to be desired in terms of 'whistling', and my whistle valve does tend to leak rather, as does my steam control valve. Further itterations are planned. The idea of the two plates that it's all mounted on, is that the boiler/engine assembly can be relatively easily removed from the base board for use in a steam launch. And finally, the base board itself is a chunk of laminated oak kitchen work surface, scrounged as an offcut from a neighbour when they were re-modelling their kitchen. Anyway, I know it's not exceptional in the overall scheme of things produced by members of this forum, however, I am quite chuffed (scuse the pun) with it.
PhilPassmore is offline
11
People Like This
Old 01-05-2018, 05:45 PM   #2
deeferdog
Liked 209 Times on 86 Posts
Likes Given: 49
Default
Looks good, if it was mine, I'd be chuffed too. Cheers, Peter
deeferdog is offline
Old 01-05-2018, 08:43 PM   #3
Brian Rupnow
Liked 4127 Times on 3273 Posts
Likes Given: 37
Default
That's a lovely layout and very nice craftsmanship. Good on you!!---Brian Rupnow
Brian Rupnow
Brian Rupnow is offline
Old 01-05-2018, 10:35 PM   #4
Herbiev
Herbiev's Avatar
Liked 291 Times on 247 Posts
Likes Given: 97
Default
Well done. Looks great.
Herbie
Hallett cove
South australia
Herbiev is offline
Old 01-06-2018, 01:57 AM   #5
JCSteam
Liked 61 Times on 55 Posts
Likes Given: 343
Default
All that to power a little occilator, I love it
A great job and beautifully crafted
JCSteam is offline
Old 01-06-2018, 06:17 AM   #6
Cogsy
Cogsy's Avatar
Liked 530 Times on 407 Posts
Likes Given: 529
Default
Fantastic - you should be proud!
Al.
______________________
I'd like to be a perfectionist, but I lack the patience...not to mention the skill...
Cogsy is offline
Old 01-06-2018, 04:01 PM   #7
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 123 Times on 112 Posts
Default
Very Nice.
Lots of shiny parts and intricate plumbing, too.
The boiler cladding looks appropriate. I think your two-piece method is a good thing and I'll try to remember it for the future.
Thank You for posting,
--ShopShoe
ShopShoe is offline
Old 01-07-2018, 02:26 PM   #8
minh-thanh
minh-thanh's Avatar
Liked 129 Times on 48 Posts
Likes Given: 578
Default
Looks great !!!!
Minh Thanh
" Nothing is too small to know, and nothing too big to attempt."
minh-thanh is offline
Old 01-26-2018, 01:50 AM   #9
justintro8487
Liked 1 Times on 1 Posts
Default
Very nice build!
justintro8487 is offline
Blogwitch Likes This
Old 01-26-2018, 03:18 AM   #10
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
Default
Lovely well engineered display.
Keep up the good work
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Some people build Models, others build CNC PLASMA machines rodw CNC Machines and Conversions 68 08-20-2017 09:38 AM
Gas Turbine build, pictorial build log. rythmnbls Photos and Videos 103 03-02-2016 09:39 PM
V12 Build DickInOhio A Work In Progress 146 05-21-2014 09:43 PM
6" Copper HRT Boiler Build (warning, long build and lots of pictures) A310 Boilers 21 04-06-2013 08:03 PM
What shall I build? Julian General Engine Discussion 6 05-02-2010 11:16 AM
