Home Model Engine Machinist > Building Them > Engines From Castings > Stuart Twin Launch Engine from set of castings
Old 02-22-2012, 06:18 PM   #1
shearwater
Liked 2 Times on 2 Posts
Default Stuart Twin Launch Engine from set of castings
Hi all, this is my Stuart Twin Launch engine built from a set of castings,
the crankshaft is not included in the set or any of the reverse gear.
I made the crankshaft webs from 30mm dia ENiA and brazed them to
the silver steel shaft, I also scratch built the Scotch return flue boiler.
http://www.youtube.com/watch?v=NgS2U...ature=youtu.be
Edited to embed link - Arnold
shearwater is offline
Old 02-22-2012, 07:29 PM   #2
arnoldb
arnoldb's Avatar
Liked 93 Times on 178 Posts
Default Re: Stuart Twin Launch Engine from set of castings
Hi shearwater
Welcome to HMEM!
That's quality-looking engine and boiler building you show in the video
Do you have a video of the engine running under steam ? - that would be great!
Kind regards, Arnold
"Necessity, who is the mother of invention" - Plato
arnoldb is offline
Old 02-22-2012, 08:11 PM   #3
shearwater
http://www.youtube.com/watch?v=ZTblV...ature=youtu.be
Hi Arnold, This is a video of the engine running on 20psi compressed air.
not easy on your own to hold camera and tacho, the flywheel is not running out its covered with black tape to get a tacho reading.
The boiler has been hydraulic tested to 160 psi and steamed with pressure relief valve set at 60 psi.
Mick
Old 02-22-2012, 08:27 PM   #4
bearcar1
Senior Member
Liked 43 Times on 43 Posts
Great pieces of work Shearwater. Did you work to a particular set of drawings for your boiler? I would love to see them as the unit appears to be very robust.
BC1
Jim
bearcar1 is offline
Old 02-22-2012, 08:45 PM   #5
fcheslop
Liked 125 Times on 98 Posts
Likes Given: 7
Stunning as is the launch just wish I could build to that standard
best wishes Frazer
fcheslop is offline
Old 02-22-2012, 08:49 PM   #6
arnoldb
arnoldb's Avatar
Thanks for the video Mick
It runs well on air - I like the slow-speed running.
Keep us updated on your progress - the bits visible from the boat itself looks great as well!
arnoldb is offline
Old 02-22-2012, 09:33 PM   #7
shearwater
BC1
Jim
Hi Jim, I did not work from a set of plans, a very good friend of mine
a very experienced engine who has built many boilers and engines steered me in the right direction as this is only my second venture into
steam.
Regards Mick
Old 02-22-2012, 09:38 PM   #8
shearwater
Thanks for all your interest and comments.
http://www.youtube.com/watch?v=wAiRf...ature=youtu.be
Old 02-22-2012, 10:09 PM   #9
rhankey
rhankey's Avatar
Liked 37 Times on 31 Posts
Dang that is sharp looking boat, engine and boiler. I am very impressed. I'm building a Stuart triple right now as my first engine and forray into metal working, and have an old Stuart twin launch casting kit being sent to me at the moment for my next engine. I think it will be some time before I consider making a boiler or a boat. Your pictures are quite inspirational.
Robin
rhankey is offline
Old 02-26-2012, 08:23 AM   #10
PeeWee
Liked 6 Times on 6 Posts
Great work mick, i followed the build closely on Mayhem
Ian
Still Sane? who knows who cares
PeeWee is offline
Stuart Twin Launch Patrik A Work In Progress 15 07-28-2017 06:22 PM
Stuart Turner Launch engine con rod. KBC Engines From Castings 36 12-18-2015 12:12 PM
Twin launch engine update imation A Work In Progress 3 07-12-2012 02:04 AM
Twin launch engine imation A Work In Progress 4 04-24-2012 12:09 PM
Small twin launch steam engine gbritnell Photos and Videos 4 07-28-2007 02:17 AM
