Home Model Engine Machinist > Showing Them > Finished Projects > homemade grinder tool rest
Old 01-07-2018, 01:07 PM   #1
celsoari
from Brazil
Liked 15 Times on 4 Posts
Likes Given: 17
Default homemade grinder tool rest
my home made tool rest (audio in portuguese)
greetins from Brazil
celsoari is offline
6
People Like This
Old 01-07-2018, 02:19 PM   #2
goldstar31
Liked 340 Times on 291 Posts
Likes Given: 537
Default
Muy Bien!
Some time back, I bought the Veritas rest which is fine, then I bought the Acute tool and cutter plans from Eccentric Engineering which has a similar rest but can be more easily locked with Bristol clamps.
What came out of the plans was a simple little jig to set- almost automatically, the angles for tool bits. I have already suggested the maths for this in earlier posts but whether anyone has got around to actual reading and then DOING it is one big imponderable.
What appears here is the ability to slide lathe and end/slot drills by adding a pair of holders similar to the one designed by Arnold Throp of Dore Engineering and was sold as castings by Ivan Law as the Kennet
It is far easier to set up than the Quorn- or so Mr Throp mentioned to me at an exhibition
Cheers/Salud
N
goldstar31 is offline
Old 01-11-2018, 05:31 PM   #3
Tad Wicks
Liked 3 Times on 3 Posts
Default
Ótimo trabalho
Eu também gosto da música Tad
Tad Wicks is offline
celsoari Likes This
Old 01-13-2018, 05:43 PM   #4
MUUTOR
MUUTOOR
MUUTOR's Avatar
Liked 1 Times on 1 Posts
Likes Given: 15
Default
Parabens. Se tivesse algumas legendas em ingles talvez ajudasse os nossos amigos anglo-saxonicos. Abraco.
Nice tool improvement by our friend of Brasil.
MUUTOR is offline
celsoari Likes This
Old 01-14-2018, 12:29 PM   #5
celsoari
from Brazil
Likes Given: 17
Default
Dear friends Muutor, Tad and goldstar31, thanks for yours coments
( obrigado pelos comentários amigos)
Celso Ari
from Brazil
celsoari is offline
Old 01-14-2018, 01:40 PM   #6
goldstar31
Likes Given: 537
Default
Pleased to help!
Two points are probably constructive.
The first is that you could continue on your work tables with the Eccentric Acute tool grinder.
The second is that Arnold Throp put an additional slide on top of the grinding rests and then added a choice of three work holders to do,
1. lathe tools
2. ends of end mills
3. grind slitting saws
His design was called the Kennet.
This is no longer available but could easily be copied in much the same way as the Worden which is available as a kit or kits from Hemingwaykits in England.
Apart from this--do you have a better choice of music, please?
I hope this adds to your information.
Norman
Old 01-16-2018, 11:17 PM   #7
JCSteam
Liked 49 Times on 45 Posts
Likes Given: 211
Default
Very nice grinding rest, having just got a grinder up and running I could do with something like that myself. Loved the video too, nicely edited
JCSteam is offline
celsoari Likes This
Old 01-17-2018, 11:21 AM   #8
goldstar31
Likes Given: 537
Default
Probably getting a cheap secondhand arc welder and learning how to use it would really extend what can be done with limited tools.
I may only use my MIG( Metallic Inert Gas welder using the Active gas technique) welder once in a blue moon but I'd be lost without mine.
( we must get together when the weather gets warmer, eh?)
Norm
JCSteam Likes This
My Tool Grinder. BaronJ Tools 60 10-11-2014 01:55 PM
Mini Lathe Tool Lifting, Should I Remove the Compound Rest? jtrout13 General Engine Discussion 13 08-22-2012 03:44 AM
Lathe tool grinding rest / guide ? David Morrow Tools 12 06-20-2011 05:22 AM
Tool Grinding Rest ShedBoy Tools 11 06-06-2011 04:06 AM
HF Tool Grinder Paulsv Tools 7 06-26-2010 03:27 AM
