Home Model Engine Machinist > The Tools and Tips > Tools > Craftex CT039 or B2227L
Old 12-15-2017, 01:55 AM   #1
sandoz
Liked 2 Times on 1 Posts
Default Craftex CT039 or B2227L
Hello,
I'm looking to*buy my first lathe. The last time I used a lathe was in high school shop class over 20 years ago but I have a few things I want to make and have the opportunity to buy the CT039 or the B2227L. I've done a little research on the two lathes and have found pros and cons on each. I was wondering if anyone has used them both and can help me out with my decision. There are a lot of good things I found on both.
Thanks
sandoz is offline
Old 12-15-2017, 10:10 AM   #2
Nick Hulme
Liked 64 Times on 48 Posts
Likes Given: 30
Default
Given that capacity over the cross slide and length between centres length are close to identical I'd go for the one with the larger bore, if nothing else it gives you more choices of stock size where you don't have to chop off short sections to be able to work.
The only point where more through capacity becomes a problem is when the lathe gets large enough that RPM is limited and high RPM is nice to have for small jobs and some material/tooling combinations,
Nick
W.C. Fields said "You can't cheat an honest man", he should have followed that with "But, you can always find a credulous fool if you need one"
Nick Hulme is offline
Old 12-17-2017, 08:55 PM   #3
Wizard69
Liked 196 Times on 174 Posts
Default
Just a quick note as i dont have time at the moment to search out those lathes but if one of them has a bolted on chuck as opposed to a threaded spindle id go with the solidly mounted chuck.
I bought a generic 9x20, with a screwed on chuck and frankly it is frustrating. In an ideal world running the spindle in reverse should be as easy as running it forward.
Now that i got that off my chest a few other things to consider. A T-slotted cross slide is an advantage as is a tumbler reverse.
Wizard69 is offline
Old 12-17-2017, 09:25 PM   #4
canadianhorsepower
canadianhorsepower's Avatar
Liked 296 Times on 236 Posts
Likes Given: 1411
Default
Hi The B227l is the least to go with
it's a great little machine trouble free and cheap.
I had all of them now I have a cx707
the best one CX709 worth every penny
Luc
"if you dont stand for something
you will fall for everything"
canadianhorsepower is offline
Old 01-13-2018, 09:06 PM   #5
Dunc1
Liked 9 Times on 8 Posts
Default
I have the B227L. Very ruggedly built. got mine on sale several years ago.
Make certain to change the headstock oil b4 use and make certain that the gasket under the headstock cover plate is not "flopped" into the space. See
http://bbs.homeshopmachinist.net/thr...rbox-noise-fix
Lead screw is 7 tpi - unusual but meets my needs.
It lacks a tumbler gear; L-hand threading is not possible unless home-built. Plans are out there.
The accessories (for eg steady rest, follower rest, faceplate) are used by (an)other lathe(s) in the Busy Bee system. That said, if required, I would not deliberate too long.
Few other posts: http://bbs.homeshopmachinist.net/sea...archid=2685124 and general queries on the 'net/youtube should get a few more thoughts.
Dunc1 is offline
Old 01-14-2018, 07:16 PM   #6
Brian Rupnow
Liked 4003 Times on 3186 Posts
Likes Given: 36
Default
I was sure that I responded to this post before, but here it is again. the B2227L is a great lathe. I had one for many years, and I loved it.---Brian
Brian Rupnow
Brian Rupnow is offline
B2227L Reverse Tumbler Dunc1 Machine Modifications 2 08-17-2015 11:40 PM
Craftex 7x8 Lathe gwapoboy Machine Modifications 25 02-02-2015 05:00 PM
Craftex CT039 9 X 19 info RobCleveland Tools 6 12-04-2013 10:41 PM
Reverse lead screw on a B2227L digiex-chris Machine Modifications 8 11-07-2012 05:20 AM
Busy Bee/Craftex mygrizzly1022 Tools 10 12-27-2011 05:00 AM
