Project of the Month built by Rustkolector
Home Model Engine Machinist > CNC and 3-D Printers > Software and Programming > Proxxon CNC Mill and nccad9 software
Old 02-10-2018, 09:52 PM   #1
Lofty76
Default Proxxon CNC Mill and nccad9 software
Hello everybody, Recently, in an attempt to get up to date I purchased the above in order to learn some basic cnc programming.Unfortunately the nccad software is mostly in german and support from Max computers (the vendors) is not overly forthcoming. I want to try and learn to manufacture loco nameplates - the ones with raised letters, for a start project.
Can anyone recommend software that will work with the machine and that I can understand?
Many thanks for your help in advance
Lofty
Lofty76 is offline
Old 02-11-2018, 02:55 AM   #2
kvom
kvom's Avatar
Liked 605 Times on 483 Posts
Likes Given: 283
Default
I took a look at the nccad/max website. As far as I can tell nccad is a cam program that works only with imported STL 3D files. 3D machining is probably not what you want for something like nameplates.
Does your machine have a separate control program like Mach3?
kvom is offline
Old 02-11-2018, 10:41 AM   #3
Lofty76
Default
Many thanks for your reply.
The program seems fine for standard engraving, I have worked out to input the machine limits / parameters, setting tool zero height etc, and then running a simple text program ( using a pencil in the machine collet on card clamped to the table), probably not the best way forward but I am beginning to understand the way things work.
I did find a program called VCarve which shows exactly what I want to do. but I can't control the machine from it, the only way that I could see was to export the vcarve code into the nccad program as the trial version of vcarve doesn't allow export directly to the machine.
Does Mach 3 have a usable trial?
Lofty76 is offline
Old 02-11-2018, 12:45 PM   #4
kvom
kvom's Avatar
Likes Given: 283
Default
As long as g-code can be imported to the control that's the way to go.
kvom is offline
Old 02-18-2018, 01:23 PM   #5
Lofty76
Default
Thanks Kvom, Mach 3 works a treat, much obliged.
Lofty76 is offline
Proxxon mf70 larsinist General Engine Discussion 5 12-06-2015 12:03 AM
Sherline 4000 vs Proxxon PD230 mimoletti Tools 2 01-05-2015 08:41 PM
Proxxon PD400 Karlas General Engine Discussion 17 09-01-2014 12:44 AM
Can all the software for the mill be split up? richtes Software and Programming 5 08-09-2014 05:54 PM
HSS Bits from Proxxon gus General Engine Discussion 11 01-16-2013 02:22 PM
