Project of the Month built by driller1432
Home Model Engine Machinist > Whats Left? > The Break Room > Contemplating Grizzly's Horizontal/Vertical milling machine
Old 01-12-2012, 11:07 PM   #1
willburrrr2003
Liked 12 Times on 11 Posts
Default Contemplating Grizzly's Horizontal/Vertical milling machine
Hello all, I am contemplating purchasing this machine with my tax return this year... Please give me your opinion on this machine, or even better if you have tried it or own it tell me how you like it. Here is the catalog page from Grizzly http://www.grizzly.com/catalog/2012/Main/550 , the machine is the one at the bottom of the page. It looks like it will do everything I need it to do, and complement my CNC minilathe nicely.
Will R. Everett, WA.
willburrrr2003 is offline
Old 01-13-2012, 12:36 AM   #2
lazylathe
lazylathe's Avatar
Liked 25 Times on 25 Posts
Default Re: Contemplating Grizzly's Horizontal/Vertical milling machine
Hi Will,
That machine also caught my eye when i was looking through the new catalogue!
Looking through the specs it has a very small cross travel, just over 3 inches.
Since it is a new addition i am not sure if anyone will be able to provide any feedback on it.
It is neat that it can do double duty as a vertical and horizontal mill though.
Good luck in your quest!
Let us know what you decide on!
Andrew
The best part about procrastination is that you are never bored, because you have all kinds of things that you should be doing.
Time is money, money is the root of all evil, and knowledge is power. Therefore, procrastination is the key to world peace.
lazylathe is offline
Old 01-13-2012, 01:18 AM   #3
ninefinger
ninefinger's Avatar
Liked 33 Times on 27 Posts
Likes Given: 18
I saw this discussed on another forum and noted that Grizzly had added it to their lineup. I personally thought that the Y axis travel was just too small but it depends on your own needs. Also when configured as a vertical mill the clearance between the spindle and the work is really small...
You can see a review of it here http://www.mini-lathe.com/mini_mill/reviews/U1/U1.htm
Hope that helps a bit.
Mike
ninefinger is offline
Old 01-13-2012, 03:47 AM   #4
shred
Liked 34 Times on 34 Posts
I think the lack of quill / drilling feed and minimal room in Z will be a nuisance. The concept is an interesting one though.
shred is offline
Old 01-13-2012, 06:00 AM   #5
willburrrr2003
Thanks for the responses guys, I read through Mike's link and do find the y cross travel to be smaller than I thought from first glance....I was thinking the z wouldn't be to bad if I used collets with 3/8" endmills and a range of collets for drilling... I could make the collets on my CNC minilathe. It was my intention to CNC the mill so I could drill will the z axis at that point. I think the Y travel is gonna be the deal-breaker....I need more. Shame, I loved the vertical mode setup.... it was the most like a knee-mill and that's what I am looking for a mini knee-mill.....basically like a tabletop bridgeport
Will R.
Old 01-18-2012, 08:41 PM   #6
purpleknif
Liked 42 Times on 40 Posts
Likes Given: 191
Take a look on E-bay at the mill sold by Big Dog Metalworks. That's the one I got. More X & z travel and an overall heavier machine. I like mine a lot and I'm a full time machinist.
purpleknif is offline
Old 01-19-2012, 01:13 AM   #7
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 684 Times on 510 Posts
Likes Given: 69
What size horizontal arbor has it?
Unless it can accept standard size cutter bores, say 1" or 1.25", then you are going to be making all your own cutters, unless you are going to limit yourself to slitting saws.
These are two basic standard sizes that allow you to buy at very reasonable prices, say off ebay, otherwise specials will start to get very expensive, or as stated, you will be making your own.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 01-19-2012, 10:03 AM   #8
geoff
Liked 21 Times on 15 Posts
An interesting machine, i thought i had seen it somewhere else, it`s a Sieg SU1 universal mill sold in the U.K. by axminster tools and costing a whopping 984.00 they also do a power feed for it.
Geoff
geoff is offline
Old 01-19-2012, 10:50 PM   #9
Tin Falcon
Tin Falcon's Avatar
Liked 814 Times on 647 Posts
Likes Given: 18
Nice looking machine . I like the idea of a bench top combo knee mill. 11 7/8 in X so you can slot or surface a long piece.
they a bit tight in the z almost 5 inches less than the X-2 and a little tight in the Y
I like the concept though. Could be interesting if one had the time and money to open the envelope a bit.
Ad maiorem dei gloriam - Ad vitam paramus
Amat victoria praeparatio diligens
Tin Falcon is offline
Old 01-21-2012, 07:06 PM   #10
MachineTom
Senior Member
MachineTom's Avatar
Liked 121 Times on 92 Posts
Likes Given: 7
The horizontial aspect appeals to me, but the vertical distance is very small by the look of it. The spec's do not state the distance. If a 3" cutter was on the Hor. spindle, the work height might only be an inich+/-. A speed of 200rpm on a 3" cutter is way fast, fast even for a 2" cutter. Assuming it take's an R-8 in the horz. spindle, that provides for a 1" arbor, but I don't recall seeing supported arbors as short as the one in the photos.
The lack of geared down low speed I believe kills it use as a Horz mill. With the right gearing a 1/2 motor is fine on a horz mill, but a DC motor slowed to a crawl is not the way to do it.
My Wheels don't slow me down
MachineTom is offline
Milling machine or vertical slide for the lathe, which should I buy? Kaleb General Engine Discussion 27 10-16-2011 09:56 AM
SOLD: Haighton Major Horizontal Miller with quill feed vertical head BillTodd Buy / Sell / Trade / eBay 3 05-20-2011 09:58 PM
homemade vertical milling machine johnthomp Plans 14 04-24-2011 02:35 AM
bridgeport manual vertical mill milling machine w/rotary table,vise,angle head, paulmars Buy / Sell / Trade / eBay 2 01-01-2010 03:59 PM
Horizontal and Vertical Versions of the Same Engine Philjoe5 Photos and Videos 8 06-06-2009 08:39 PM
