Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > The Shop > South bend 9 restore question
Old 04-02-2017, 07:59 AM   #11
MRA
Liked 16 Times on 14 Posts
Default
I was helping an old friend of mine clear his shed - he (preciently enough) wasn't expecting to be needing it much longer. On his South Bend 9" lathe, the plain headstock bearings were held in sprung cast iron (!) caps which were only split on one side, with a bolt through the split. I was surprised how easy it was to take the play out of it, and then go too far and render it tight. I would suggest slackening yours off until you can rattle the spindle up and down, and then do it up until this *just* stops.
MRA is offline
Old 04-03-2017, 10:05 PM   #12
Naiveambition
Liked 49 Times on 35 Posts
Likes Given: 21
Default
Was able to apply power to the spindle and seems ok. The real test will come when cutting so we will see what happens.
I still need to finish the 3 jaw chuck and make a bolt for the swivel in the compound. I did finish all of my major cleaning and painting. Am really happy so far. Here's some pics of the lathe as of now. ImageUploadedByModel Engines1491257335.441707.jpgImageUploadedByModel Engines1491257352.184624.jpgImageUploadedByModel Engines1491257369.362435.jpgImageUploadedByModel Engines1491257383.707903.jpg
Only problem is the pulley system in the rear bounces as it turns. Only weight is used to hold tension on the belt so that will be addressed. Any thoughts
Naiveambition is offline
2
People Like This
Old 04-03-2017, 10:48 PM   #13
bazmak
BAZMAK
bazmak's Avatar
Liked 1053 Times on 594 Posts
Likes Given: 831
Default
Only that you are doing a great job,thanks for posting
bazmak is offline
Old 04-03-2017, 10:51 PM   #14
MRA
Default
I _think_ these normally have a rather long eccentric-cam lever to lock the countershaft, with a kind of threaded turnbuckle in the middle to set the tension. Maybe you've been there, but you can look it up on 'lathes.co.uk' which will give you lots more info. From there I note that someone seems to have replaced the very odd (but original) setup of a v-belt driving a plain wheel on the countershaft, with a v-pulley, on yours.
MRA is offline
Old 04-04-2017, 12:41 PM   #15
ShopShoe
Senior Member
ShopShoe's Avatar
Liked 116 Times on 106 Posts
Default
I'll add my kudos to the job you are doing with this. I agree that the the drive systems looks like it's been modified.
I believe that mrpete222 on YouTube has some videos on cleaning up Southbend lathes where you might see how the drive system is configured.
--ShopShoe
ShopShoe is offline
Old 04-04-2017, 08:16 PM   #16
DJP
Liked 71 Times on 62 Posts
Default
My old SB has a tensioner for the flat belt so that you can easily change speeds. However, given the low hp of my motor I leave mine at the lowest chuck rpm possible. Your set up should work OK as long as you leave it in one setting. I think that mine runs at 600 rpm.
The nice part of the flat belt drive is that it will slip if you crash a tool into a work piece. It's a very forgiving set up.
That said, the whole machine is past its prime when it comes to parting off. I need to lock down everything for rigidity and pray when making the cut. Some days a hack saw and end facing afterwards works better.
Still, I love my 1940s SB even with its limits. Mine is not a clean as yours so you win.
DJP is offline
South Bend 8K photos mikbul Tools 410 02-28-2016 10:36 PM
South Bend number 5? nkalbrr Tools 6 11-17-2014 03:53 AM
I just recieved my new South Bend 8K djmachinist Tools 26 12-30-2013 06:28 PM
ER Collets for my South Bend Mosey General Engine Discussion 19 11-25-2011 08:10 PM
South bend lathe o.h.cam General Engine Discussion 2 08-09-2011 11:21 PM
