Project of the Month built by driller1432
Home Model Engine Machinist > The Tools and Tips > The Shop > Setting up Shop Questions - from an NZ learner
Old 08-23-2017, 09:42 AM   #591
joco-nz
joco-nz's Avatar
Liked 118 Times on 90 Posts
Likes Given: 88
Default Fixing errant rear drips on the bandsaw coolant system
There is a tendency for some drips to travel back on the blade and hit the rear frame. This will get worse the more of an angle the saw starts on. So having designed up the idea for a rear catchment system to catch the errant drips here are some pics of the idea pre welding. You will see a small welding magnet in the pics. This is really just holding things in place with its weight since the parts are made from 50x50mm ali angle. Obviously if I was making these stands as semi production I would change the design to ensure the saw was fully on the inside. But since this is a one-off this little addendum should do the trick nicely.
J.
James,
Wellington,
New Zealand
joco-nz is offline
Old 08-24-2017, 08:31 AM   #592
joco-nz
joco-nz's Avatar
Likes Given: 88
Default Rear drip catch all welded up
Got the parts welded and all cleaned up. Plan for the weekend is to get things all mounted up.
J.
James,
Wellington,
New Zealand
joco-nz is offline
bruedney Likes This
Old 11-29-2017, 09:03 AM   #593
joco-nz
joco-nz's Avatar
Likes Given: 88
Default Lathe Stand Updates
Some updates to the lathe stand.
[1] Boxed in 3 sides with 19mm plywood. This has a benefit of keeping swarf and "crap" out of the shelves better but most importantly it added a massive amount of rigidity to the stand. Really surprising amounts. If I was doing this all from scratch I would incorporate 2mm steel sheet in the mix as well as a method to added wheels on slide in box section. Maybe one day if I get really enthused.
[2] Added a riser to the splash back. This will prevent stray drops going behind the lathe and also provides a convenient area to stop tool holders and other items on.
J.
James,
Wellington,
New Zealand
joco-nz is offline
bruedney Likes This
Learner in Houston says hello Naiveambition Introduction 1 03-13-2013 03:37 AM
Setting up a VFD? lazylathe General Engine Discussion 64 04-07-2012 02:31 AM
setting top slide firebird General Engine Discussion 4 12-11-2008 10:38 PM
Setting up my new shop Bogstandard The Break Room 246 09-23-2008 01:21 PM
Setting up shop. Tin Falcon Tips and Tricks 4 12-23-2007 05:18 PM
