Project of the Month built by Rustkolector
Home Model Engine Machinist > The Tools and Tips > The Shop > The Solar shed
Old 07-17-2017, 08:36 PM   #11
imation
Liked 96 Times on 37 Posts
Default
Originally Posted by Wizard69 View Post
Nice!
I've been looking into supplemental power sources for some time. It use to be that solar panels where not very cost-effective but these days there are reliability issues when if comes to electrical power. One big concern I have is that when I'm most likely to really need a back up power source my roof will have foot and a half of snow on it.
As for you shop lighting have you looked into some of the 12 VDC lighting sources out there. The 12 VDC LED solutions are very efficient and you avoid inverter losses.
In a way I'm kinda envious, you have done something that I've thought about for years.
Hi
I do have a dual power system in that there is 12V lighting in the shed as well as a line to the house which illuminates the patio, bar b q, and even the decorative water feature. I only have to turn the inverter on when I need to run the heavier equipment.
Cheers. Mike.
imation is offline
New Shed jasonh The Shop 10 09-11-2013 11:13 AM
Solar Playtime Maryak The Break Room 11 08-18-2011 09:58 AM
Solar Parabolic Collectors Antman General Engine Discussion 17 06-25-2009 12:29 AM
Solar Powered Steam sparky961 General Engine Discussion 8 07-18-2008 05:21 AM
Advice for a solar powered heat engine. cyssis General Engine Discussion 4 03-04-2008 01:15 AM
