Home Model Engine Machinist > CNC and 3-D Printers > CNC Machines and Conversions > CNC advice please
Old 03-19-2018, 04:12 PM   #11
jgarrett
jgarrett's Avatar
Liked 6 Times on 6 Posts
Likes Given: 12
Default
Baron and others,
After a lot of deep thinking I'm not sure that at my age I want to tackle something like that,,, I will probably just go with the DC motor option,
Julian
Located in N. Georgia
EMCO Maximat V10-P
Craftsman 6" 101214
Clausing 8520
jgarrett is offline
Old 03-19-2018, 06:55 PM   #12
Buchanan
Buchanan
Buchanan's Avatar
Liked 167 Times on 49 Posts
Likes Given: 467
Default
It has the advantage that there is no extras required,like programming or PC.
I have two that have run hundreds of hours on an industrial machine. They also switch on from "cold" instantaneously.
Buchanan is offline
Old 03-20-2018, 11:11 AM   #13
Rndmann9
Liked 16 Times on 10 Posts
Default
Check into a gshield. And an arduino. If you want a servo solution
Rndmann9 is offline
Old 03-20-2018, 10:55 PM   #14
Herbiev
Herbiev's Avatar
Liked 291 Times on 247 Posts
Likes Given: 97
Default
Have you looked into these https://www.omc-stepperonline.com/st...42t-m542t.html. ?
Herbie
Hallett cove
South australia
Herbiev is offline
Old 03-21-2018, 12:18 AM   #15
Buchanan
Buchanan
Buchanan's Avatar
Likes Given: 467
Default
Yes , that is the motor driver. you still need a step and direction pulse generator and a 10 amp dc power supply 24/48 volts. The pulse generator can be a PC, aduino or the other board in my first post. It has a lot of very useful features in a small simple package that needs no programming.
Buchanan is offline
Tap advice jgarrett Tools 23 03-16-2017 12:44 AM
Hi and looking for advice Tinca General Engine Discussion 4 02-13-2013 11:23 PM
I want to give you all some advice. websterz The Break Room 25 03-05-2010 02:19 PM
Advice jsa2001 General Engine Discussion 5 10-07-2009 01:51 PM
Need advice mikey00 Tools 7 02-26-2009 05:44 PM
