Home Model Engine Machinist > The Tools and Tips > Machine Modifications > CNC x2 Mill
Old 03-19-2018, 11:03 PM   #151
Blogwitch
Ex Bogstandard
Blogwitch's Avatar
Liked 715 Times on 536 Posts
Likes Given: 77
Default
It looks like you are taking the route most other people do for the Z axis.
I don't know if you realise that you are taking a large risk.
Because the stepper is only on one side of the head, that will try to cant over the head as it moves up and down, also called crabbing, which will eventually lead to uneaven wear on your Z axis slides and may even sieze up or knock your cutter off line..
The easiest way to cure this is to have a stepper either side running in parallel, so the head has equal pressure on either side.
I brought this problem up a while ago but my own illness and the death of a great friend caused me to abandon the project some time ago.
http://www.homemodelenginemachinist....ad.php?t=24086
If you go to the last post in that link, you will find a link to one of the last articles John S did before he passed away, about the build we were working on together.
If you don't try it, you will never know if you can do it!!
Blogwitch is offline
Old 03-20-2018, 03:49 AM   #152
Rndmann9
Liked 16 Times on 10 Posts
Default
Yeah I thought about that. Mainly was trying to use the material I already had mainly the belts. That and somewhere to mount it. When I first made it I only changed the y axis to a ball screw. Then changed the x. Since I had a 12mm instead of a 16mm ball screw that was ordered inadvertently went ahead and winged it for the z. These mills aren't the stiffest things anyways so I don't ever expect to get great precision. I'd be somewhat satisfied with +~- .005. I plan to get a much bigger mill in the near future ( kinda want to move first so I only move it once). It's more to learn CNC on. the whole project was sort of an impulse project...something to do with some challenge from scratch and was fun. Now I'm giving my lathe dirty looks and temped to jump on it.
Rndmann9 is offline
Old 03-20-2018, 03:56 AM   #153
Rndmann9
Default
I got tired of the backlash with no way to compensate for it which drove me to change it again. Here is the first version.
Rndmann9 is offline
Old 03-20-2018, 04:04 AM   #154
Rndmann9
Default
I noticed some loose the gas strut or torsion spring. I elected to keep the strut to maybe lesson that effect. I figured at worse the gib will wear unevenly but I plan to replace those with brass as soon as I get some stock that's the right size. The x still has some sticky spots due to the gib. I actually started this in 2016 but finally got motivated and the time to fix it
Rndmann9 is offline
Old 03-20-2018, 04:19 AM   #155
Rndmann9
Default
I actually toyed with mounting it centered but decided the extra trouble wouldn’t be justifiable. I also would need another mill. Just didn’t have much space to make it happen. All the screws are 16mm but the z. I have a spare 16mm if this one causes trouble. So far the 12 seems to be doing ok.
Rndmann9 is offline
Old 03-20-2018, 05:07 AM   #156
Rndmann9
Default
Originally Posted by Foozer View Post
Curious as to what weight the Z-Stepper has to move and is the Z counter balanced.
Robert
Itís prob 20~25lbs. Gas strut helps some. Motor muscles the rest.
Rndmann9 is offline
Lathe and Mill plans (home made making mini lathe and mill) alihureiby Plans 14 03-22-2013 12:32 PM
Mill-rite mill rebush Tools 4 05-11-2012 11:58 PM
Tramming a small mill (Sherline mill) ttrikalin Tips and Tricks 9 11-22-2009 06:58 PM
