Project of the Month built by gbritnell
Home Model Engine Machinist > Building Them > General Engine Discussion > Timing the hoglet
Old 10-15-2017, 04:00 PM   #1
neil_1821
Liked 3 Times on 3 Posts
Default Timing the hoglet
As per title really, whatís the best way to time the hoglet?
Iíve set the left piston (looking at it with the camshaft facing me) to TDC. Rotated it 90 degrees clockwise and set the inlet valve to be fully open. Does that sound about right?
Iíve also seen a few hoglet with a carburettor that you pull and a spring then closes it. Are people using ones that come off nitro engines? I have made one myself following Brianís plans but Iím not sure if my tolerances are a bit tight as itís quite stiff to operate.
neil_1821 is offline
Old 10-17-2017, 12:28 PM   #2
retailer
Junior Member
Liked 4 Times on 4 Posts
Default
I don't know about the Hoglet but if I come across an engine without timing marks I have always set the valves rocking at TDC (exhaust valve closing as the inlet valve opens opens), it has always worked for me. Keep turning the engine over and the spark plug should fire just as the piston comes up to TDC again.
retailer is offline
Hoglet valve timing. lantain1982 General Engine Discussion 5 08-04-2016 09:58 AM
Need help with hoglet timing cessna General Engine Discussion 3 01-04-2014 08:48 PM
Timing? robcas631 General Engine Discussion 7 01-28-2013 02:34 AM
Cam Timing Rustkolector General Engine Discussion 14 09-11-2011 09:18 AM
Timing diymark General Engine Discussion 2 07-04-2009 08:16 AM
