Home Model Engine Machinist > The Tools and Tips > Machine Modifications > Arduino Rotary Table for Dummies
Old 04-12-2018, 07:33 PM   #171
tjwal
Liked 5 Times on 3 Posts
Default
George
I too had difficulty getting my keypad to work. I finally wrote a sketch to test the keypad. I posted it in message #128. It echos the key presses to the serial monitor so you can see what is happening. You adjust the row and column pin assignments until it works and then copy those over to the indexer sketch.
I didn't use a schematic when I put my controller together. However, looking at the pictures and my code I came up with the attached. It is for the pro-micro that I used. It allows me to plug the keypad in without using jumpers. I think a nano would be better choice than the pro-micro just because of the idiosyncrasies of uploading to a pro-micro. I believe the nano pinout also allows for 8 consecutive pins to be used for the keypad.
I
tjwal is offline
Old 04-13-2018, 10:31 PM   #172
scoopydo
Liked 1 Times on 1 Posts
Default
Thanks, John! I do have a Pro Mini but was trying to use a nano. It does support 8 consecutive pins for analog support. I'm using the same driver as bmac used, mainly because I've bought one or two whenever I found them on sale. I do have a Pololu driver in stock but I like the higher amperage.
Agin thanks! George
scoopydo is offline
wtb rotary table toolroom Buy / Sell / Trade / eBay 7 03-06-2018 12:58 PM
Arduino control for a 3 rotary table bmac2 Machine Modifications 101 04-23-2017 01:17 AM
Rotary table Coomba General Engine Discussion 64 08-22-2016 04:34 PM
My Second Rotary Table,80 mm table. gus Introduction 75 07-29-2014 08:36 PM
Using a rotary table. radfordc General Engine Discussion 10 03-10-2009 12:58 PM
